TractorLinks.com
Tractor Talk Discussion Forum
Re: Generator test, one more time
Milan
07-10-2014 11:56:29
Gosh, guys, I am sorry, I apologize, I did not make myself clear.
I am not touting the wisdom of connecting the phases together, not at all.
I did mention that I have done this several times, and it works quite well, but, that is not the point of my original post.
I thank each of you who have responded so far, and I know each of you are right and correct in everything said so far.
But, you are all missing my point.
My point is, I want to get away from backfeeding like this, and want to connect my 120 volt generator to the house with a transfer switch in such a way that I can feed the entire house.
I am just stating that I have effectively done this many times by the method I described, so I know my 2800 watt generator can power up everything I need in an emergency power out situation.
I just want to do it legally and properly with a transfer switch and not switch individual circuits.
That is my only point and several electricians say it cannot be done, that they want no part of connecting a 120 volt generator to house wiring.
That's my only point. I was just soliciting comments on using a single transfer switch with a 120 volt generator.
They would not install one to even power up one side.
So, am I to assume that a guy with a 120 volt generator is limited to transfer switches for individual circuits or using extension cords?
Paul
07-10-2014 13:26:32
 Re: Generator test, one more time in reply to Milan, 07-10-2014 11:56:29
It just does not work to safely and nicely connect a 120 generator to both sides of a 240 house and make that work safely. 240v is a single phase, the 120 we use for smaller items is split off of that; it is not a phase of its own. So you are trying to join 2 things that already are just one thing, it gets real messy real soon.
If this were your plumbing, all your water supply comes in on one pipe. Some goes through the water heater, and some just goes on a parrallel path. Same water, but down the line one side is hot, one side is cold, and you can no longer interchange them or you have a mess.....
Your question on powering one side of the house, one of the 120v sides with a transfer switch is an interesting one. I don't understand why that wouldn't work, but I never really gave it much thought. Something to think on while on the tractor again.... Off the top of my head, wouldn't any 220v items flow the 120 across to the other side, creating problems? Hum.
Paul
