TractorLinks.com
Tractor Talk Discussion Forum
Re: Generator test, one more time
buickanddeere
07-10-2014 11:19:17
Single phase is single phase.it"s line 1 and line 2 as they are 180 degrees out of phase. Three phase uses the term phases as each line is120 degrees out of phase. It"s just the terminology to try and keep things understandable. Many countries use the term "earth" instead of "ground". In particular if speaking to somebody with an accent . The situation can be confusing. I wish the term " ground" for the chassis return on mobile Equipment had never got started. #1 your tractor has no ground rod. #2 bubba tinkerer electrician is now working on an AC system and thinks it"s ok to run return current through the ground system. . Using the same Line 1 together on a 240v four wire system requires a funky non standard plug with the two lines shorted together. Sooner or later it will be powered up by two line lines and go Ka boom. Imagine a 60 amp 120V generator on a 30 amp 240V service wired with line 1 and line 2 together. At full load the neutral will be melting with 60 amp while the lines are fine at 30. A 30 amp 240V generator on a 30 amp four wire service at full load .will have 30amp on the lines and no current in the neutral.
