TractorLinks.com
Tractor Talk Discussion Forum
Rust Converters
Traditional Farmer
07-10-2014 05:15:27
What is the Good and Bad about Rust Converters that supposedly react with the rusted metal so it doesn't
rust again? Good and bad brands?
showcrop
07-10-2014 10:31:40
 Re: Rust Converters in reply to Traditional Farmer, 07-10-2014 05:15:27
The ones that are phosphoric acid based really do as claimed when used as directed. When I was sandblasting my dump truck body I went to pick up paint and the guy behind the counter told me that I needed to "acid wash" it. That is when I started using the real stuff. The acid combines with the residual rust to form inert iron phosphate. It is especially important to use if the metal is pitted. If you don't, it is a matter of when, not if, the residual specs of rust in the pits grow enough to bubble the paint.
Mike Aylward
07-10-2014 06:53:39
I use Concrete Etching Compound which is nothing more than phosphoric acid. I get it for around $18 a gallon and it lasts a long time. I dilute it about 10:1 so a little goes a long way. No need to buy the expensive stuff when this works better and costs less. Mike
Mike M
07-10-2014 06:18:53
I'm of the group that has not had much luck with them.
Harvey2
07-10-2014 06:46:18
 Re: Rust Converters in reply to Mike M, 07-10-2014 06:18:53
Mike M,
You must be doing sumthing wrong.
The naval industry has been using Ospho for many moons.
Mike M
07-10-2014 06:58:21
 Re: Rust Converters in reply to Harvey2, 07-10-2014 06:46:18
Don't know ???
Tried a couple of brands on spots on cars.
Didn't seem to last any longer with or without it when trying to touch up rust spots.
glen sw wi
07-10-2014 06:17:07
When I worked on the offshore oil production platforms, we used Ospho. It is basically a diluted Phosphoric acid. There aren't many enviroments that are worse for causing rust.
HenryO
07-10-2014 06:32:13
 Re: Rust Converters in reply to glen sw wi, 07-10-2014 06:17:07
I have used Ospho with excellent results for over 10 years.. I tried other and still return to Ospho 2 light coats for great results.
Will Gumbert
07-10-2014 05:54:24
It has worked pretty good for me if I keep in mind a few things-
Remove oil and dirt first
Wire brush thoroughly Use only when the metal and air temperature is warm (above 60*F)
I use the brush-on type converter anywhere I can and only use the spray in hard to reach places
After first coat is black, put on a thin second coat to get an even finish.
Wait 24 hours then paint with a solvent-based paint (not water-based like latex)
I have had good success with Permatex brand brush on type but others are OK too. -Will
evilboweivel
07-10-2014 05:46:52
NAPA liquid not the spray use as directed
good luck
Ron
Harvey2
07-10-2014 05:45:01
I have used Ospho for several years, if its used as directed it will stop the rust.
When I started to use it aboot 40 years ago, I had a pickum up truck that the rear bumper would rust even if I sandblasted it and primered and painted.
When I started using Ospho as directed it didn't no more rustum again.
Goose
07-10-2014 05:40:47
They probably work in some situations, but only as a temporary "band aid" fix.
It's hard to beat sandblasting or simply cutting the rusted metal out and welding new in.
mkirsch
07-10-2014 05:33:35
I've personally never found one that truly, permanently stops the rust. Spray on the rust converter and a top coat as directed, and it's rusty again in a few months.
