Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Talk Discussion Forum
Farmall H head stuck
Nathan P.
07-08-2014 05:06:11
I posted a message a couple weeks ago about this but still haven't been able to get the head off my farmall h. the head will move a little on the one side but wont budge on the other side. I pretty sure that the head is rusted to the studs but how do I get it unstuck. Ive put PB blaster on the bolt and put the nut back on and hit it with the hammer a couple of times but that did not work.
dej(Jed)
07-08-2014 10:06:47
 Re: Farmall H head stuck in reply to Nathan P., 07-08-2014 05:06:11
I find it hard to believe that the head studs are rusted to the head. Assuming all of the nuts are off, get a large tapered chisel and a heavy hammer and have a go at it.
wayne in mn
07-08-2014 05:49:08
Did you remove the brass fitting at the rear of the head?
Won't come off unless you do.
Steve@Advance
07-08-2014 05:37:14
Check. recheck, and triple check that you found all the bolts! BTDT... Embarrassing and expensive way to find I missed one!
If you can get to them, try double nutting and getting as many studs out as possible. The rusted ones probably won't come out. Put the nut on loosely and tap side to side, try to get the rust penetrant to go down. Some heat on the head might help, but be careful! The more you can move the head around, the more likely the rust will finally give it up.
joe fabregas
07-08-2014 05:23:01
Try diesel instead of the pb and try to get the head warm, got a rose bud? I unstuck some pistons once with diesel in the cylinders and burned it off, Freed up nicely. Good luck! joe
Nathan P
07-08-2014 14:17:04
 Re: Farmall H head stuck in reply to joe fabregas, 07-08-2014 05:23:01
how did you get it unstuck after you put diesel in the cylinders? Did you just keep putting a lot of weight on the crank starter?
Zachary Hoyt
07-08-2014 05:15:30
You could try driving a hardwood wedge in the side that is stuck, just pick a spot where you won't be hitting the push rods or the studs. I don't know if that will work in you case but it may be worth a try.
Zach
