560 gas out- 560 diesel in
IaGary
I found a nice 560 diesel to replace the 560 gas.
The diesel needed a new hydraulic pump and a couple of leaks fixed. I ran it a couple of days on the Batwing mower. And she ran good.
Now to switch the fenders and get rid of the gas 560.
(quoted from post at 06:48:18 07/07/14) I found a nice 560 diesel to replace the 560 gas.
Nice. I like the 560D's. Wouldn't turn down a 560 gasser over this M I have.
Rick
You had good service out of that 560, didn't you,
Gary? My uninformed impression is that you will
have no trouble selling it.
KEH
Stan...even an Oliver guy like me can see that the diesel must be the one on the right, plugged in so it will start in July!!! LOL
Keep a spare head gasket and a set of ARP head bolts on hand, you will need them. The 560 broke IH. and the 282 dsl. was one of the biggest pos's ever made. many ended up with the sleeves around the rods.
I think that a 560 has the same engine as a 656 and if that is true it will not start in July with a fire under it without the glow plugs.But it was still a very good engine.Neighbor had a 656 utility that was his big tractor years ago that had so much blowby that he tied a gallon jug under the pipe and would pour it back in the motor every morning.That poor tractor was so wore out and he ran it for years like that plowing,disking and choping silage.I am a Deere man but IH may have had a beter engine than the Deere. Both of those tractors look nice and I would enjoy some seat time on either one.
(quoted from post at 16:34:33 07/07/14) Keep a spare head gasket and a set of ARP head bolts on hand, you will need them. The 560 broke IH. and the 282 dsl. was one of the biggest pos's ever made. many ended up with the sleeves around the rods.
No, it didn't break IH. If the 560 cause the failure how in the heck did it take from 1963 to 1986? If the 560 was going to cause the collapse of IH maybe 3 years, not 23. A lot of things cause IH to fail. Failing farm economy, not enough profit margin even though the earned far more than the closest competitor. JD's net profit margin as about 5%. IH's was about 2%. Company like that can't stay in business at 2%. Their failure to get rid of the TA earlier, lot of actors, but the 560 wasn't at fault.
Rick
you are totally full of it! have you owned one/ worked on one? or even driven one? or even know how to operate one? it was even one of the best fuel miser"s.
(quoted from post at 16:33:40 07/07/14) Stan...even an Oliver guy like me can see that the diesel must be the one on the right, plugged in so it will start in July!!! LOL
Except you'd be wrong. It's the one on the LEFT.
You can clearly see the air tube and carburetor on the one on the right. A diesel would have fuel filters there.
