Yesterday's Tractor Co. The Right Parts, Right Away
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Talk Discussion Forum
IH 300 utility
Nv IH
07-06-2014 22:49:59
74.34.119.25
Hi,new to the forum someone has given me an international 300 utility Serial number 28080 SJ. It has Ben setting for about ten years I think. It has a bucket,five foot blade. The right rear tire(13.6x28) and wheel is bad from being eaten by what was in it for ballast. Anyway I do not know how to decode the serial number and not sure what size wheel to order. The tractor is in Wyoming I live in Nevada. Any help is appreciated.
[Reply]   [No Email]
Mike (WA)
07-07-2014 13:11:34
69.10.199.195
 Re: IH 300 utility in reply to Nv IH, 07-06-2014 22:49:59
They have rims right here, on YT site.
[Reply]  [No Email]
Nv IH
07-07-2014 08:57:04
166.137.208.48
Ok thanks everyone. I will ask Dad to
Go measure that wheel. I am fairly
sure it bolts on with carriage blots. Is
there a web page for decoding
serial numbers? Thanks again
[Reply]  [No Email]
big fred
07-07-2014 11:30:59
174.21.21.91
 Re: IH 300 utility in reply to Nv IH, 07-07-2014 08:57:04
I just recently had the left rear wheel off my 300U. The 6 bolts on the hub came off easily, and re-mounting the wheel was a piece of cake with the hub to guide the wheel center. I don't think I'd take the rim off the center while it's on the tractor. Too hard to line it up again.
[Reply]  [No Email]
wayne in mn
07-07-2014 07:18:43
71.8.150.168
According to the serial number reference on the left side of this page your tractor is a 1956 model.
[Reply]  [No Email]
JMS/.MN
07-07-2014 06:33:13
209.237.125.241
A 13.6 tire is normally on a 12 inch wide rim. However, that is not set in stone.....things get changed over time. Measure the rim where the bead contacts the rim. Depending on rust damage, the rim may be repaired using a section of a similar donor rim.
[Reply]  [No Email]
mkirsch
07-07-2014 06:13:40
65.199.189.6
Depends on whether your tractor has 6-loop rims or power adjust rims (aka "spinout"), what you buy.
If your rims are bolted on with 6 simple loops and carriage bolts, the choice is obvious. If the rim has curved rails around the inside, it's a "spinout."
The rim width is printed on the tire. It will either be an 11" or 12" rim.
The rim dealer will be able to help you.
[Reply]  [No Email]
Russ from MN
07-07-2014 05:49:04
68.235.89.18
Someone else will know more about the rim. What I would do before ever trying to turn the engine over is take out the spark plugs and squirt some ATF into the cylinders, even if it's not stuck it will be good for everything. If it's stuck you may need to add some acetone to the ATF!
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
