Yesterday's Tractor Co.
Shop Now View Cart
Tractor Talk Discussion Forum
Re: Wisconsin throtle to a I.H. Skid steer loader 3200A
07-06-2014 22:07:06
I"ve got several V4 Wisconsins and, best I can remember from working on them, the only thing missing in the pic is the link from the lower part of the pivot to the throttle shaft on the carb. The way it"s designed you set the spring in one of the holes on the arm of the governor to get a gross speed/range setting. From there you use the nut on the threaded end of the rod to set the specific speed within the range provided between the different holes.
Brent Zappe
07-07-2014 19:37:49
 Re: Wisconsin throtle to a I.H. Skid steer loader 3200A in reply to NCWayne, 07-06-2014 22:07:06
Thank you NCWayne. I was not to sure if I had all those parts. I guess the govenor will be pulling on the spring which will work the rod tension. I do have the carburator and its link. I still have to rebuild the craburator before mounting it on.I still have to cut and make a rod for the hand throttle to the govenor link.So all that is a measure, cut and thread. To make it work with a compelet thorttle rod to engine fromthe operator seat. Thanks again Brent.
