Yesterday's Tractor Co. Same-Day Parts Shipping Available
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Talk Discussion Forum
Spraying weeds around stored equipment
Edd in KY
07-06-2014 18:51:39
98.23.19.38
I need some practical advice, not the kind you can find on the label. I have a gravelled area where I park my old implements, outside and exposed to the elements. This year I have grown a rather hardy group of weeds, under and around the old, discs, plows, rakes etc. The tractors and balers are in the barn.
Question: Can I spray roundup on these weeds (and naturally get some overspray on the equipment) without causing undue damage and corrosion? This is all old equipment, the paint is mostly gone and the value left with it.
[Reply]   [No Email]
Jiles
07-07-2014 07:01:24
69.137.29.28
 Re: Spraying weeds around stored equipment in reply to Edd in KY, 07-06-2014 18:51:39
Don't know if it will cause more corrosion but I used to spray my scrap pile and after many rains over a long time, I could smell the herbicide when burning or welding items from pile.
I am sure it did not penetrate the metal but couldn't understand why it didn't wash off.
Something else to consider:
Many years ago, I sprayed Roundup at 2 oz. per gallon =50 gal. along an old fence. After about two weeks, there was just a small amount of kill.
I called the Auburn Extension Service and was told that I should not have sprayed in drought conditions! It had not rained in MANY weeks and it was definitely drought condition.
I waited until it rained and two days later, I sprayed another 50 gallon mix and in one to two weeks, everything was dead.
I learned a valuable lesson although the instructions clearly stated to not spray in drought conditions!
[Reply]  [No Email]
NNP
07-07-2014 06:43:47
66.66.112.196
I use old carpet too. free
turn it over every year or 2 because your tractor tires will bring dirt in on it and stuff will grow.
(watch for tacks on pulled up old carpet)
Implement parking area is also a good spot to dump all the old calcium out of tires.
kills most everything, and discourages new growth for some time.
[Reply]  [No Email]
Bill in il
07-07-2014 06:34:09
66.94.208.1
Never have had a problem doing that. Usually spray about twice a year.
[Reply]  [No Email]
George Marsh
07-07-2014 03:53:41
50.121.115.1
I have same problem. I used to have wood chips under my stored equipment until the chips decayed and weeds came. I'm looking for used carpet. Plan to put it down upside down on ground, put equipment on top. I'm thinking carpet will prevent weeds from growing longer than roundup will.
[Reply]  [No Email]
fixerupper
07-06-2014 19:44:59
100.42.82.100
Pramitol is a good one if you can still get it. It kills the ground for several years so you don't have to spray again in a month like you do with glyphosate. Pramitol will leach out sideways some so be careful.
[Reply]  [No Email]
Davis SC
07-06-2014 19:22:13
70.197.164.83
RU is not supposed to be compatible with Galvanizing, but I don't think it really would damage it...
[Reply]  [No Email]
OH - 961
07-06-2014 19:45:14
66.19.61.173
 Re: Spraying weeds around stored equipment in reply to Davis SC, 07-06-2014 19:22:13
Davis SC,
The first good rain should pretty well rinse off whatever residue is left on the metals. I think most damage from spray solutions is due to constant moisture exposure, as much as anything else.
I doubt that one exposure to galvanized would do much harm, as long as it isn't long term.
Myron
[Reply]  [No Email]
jm.
07-06-2014 19:02:59
162.72.81.167
Got an area like that where I empty the sprayer about ever timer I have roundup left. Keeps the weed down and have not noticed any problems . There is also Primatol or something like that will kill the ground completely.
[Reply]  [No Email]
OH - 961
07-06-2014 19:09:44
66.19.61.173
 Re: Spraying weeds around stored equipment in reply to jm., 07-06-2014 19:02:59
jm,
Are you just dumping the roundup on the ground?
It is supposed to kill through foliage contact only, rather than being a soil contact herbicide.
Myron
[Reply]  [No Email]
jm.
07-07-2014 05:09:00
162.72.81.167
 Re: Spraying weeds around stored equipment in reply to OH - 961, 07-06-2014 19:09:44
No Myron we have hand wand plugs of all the spray rigs to just plug on a hand wan on the was outs..
[Reply]  [No Email]
OH - 961
07-06-2014 19:01:28
66.19.61.173
Edd, No more damage than rain and dew normally cause, AFAIK. There shouldn't be anything particularly damaging about Roundup or other glyphosates.
If you are using a hand sprayer, mix 2 oz. of the 41% Roundup per gallon of water, and soak the weeds thoroughly.
Some of the tougher weeds don't seem to be effected with a weaker mix.
Myron
Edit:
I should have mentioned that Roundup claims to be rain - safe after 2 hours, but I like to give it a little more time than that if possible before it gets rained on.
This post was edited by OH - 961 at 19:13:29 07/06/14.
[Reply]  [No Email]
Notjustair
07-06-2014 18:57:34
174.229.65.132
You can get 24D that is supposed to be easier on equipment. I've purchased it by the gallon to use around the barnyard in my pull behind sprayer (not crop sprayer). It is milky white. I don't think it works as well.
They will all say they are non corrosive or safe, but there's a reason sprayers rust at the joints and pins freeze up. That stuff is hard on things. If it were me I would use something with more of a residual so you are constantly doing it. Roundup is contact only. Watch your runoff.
[Reply]  [No Email]
Lazy WP
07-07-2014 05:06:00
67.142.168.24
 Re: Spraying weeds around stored equipment in reply to Notjustair, 07-06-2014 18:57:34
2-4D won't touch any grass, unless put on way to heavy. Glyphosate won't bother metal, that I know of. Now is you add AMS like a person should, it will cause rust.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
