John deere 2355 hydraulic issue
Del mayhew
New User
I have a 1987 JD 2355 with no hydraulics on the front end (no loader functions on steering assist) however the pto works. This problem happened after a round bale was lifted and the bucket linkage broke. My question is where is the relief spool located and or what else could I be looking for? Thanks for any input
Del
Does the scv operate ?
You did not state what brand or model of loader . Assuming it"s the typical JD 240 of that era.
On 240s There is a relief valve to dump excess pressure from the hydraulic ram . Instead of failing a seal or hose if somebody took a Bonzi run at a load.
It"s a closed Center hydraulic system so don"t look for a relief valve on the 2250psi side of the system.
