Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Talk Discussion Forum
2440 making oil??????
Denny One
06-11-2014 06:15:20
Looking for some help here guys. I have a JD 2440 that seems to be making oil. When I changed to oil it was about a quart high and smelled of diesel.
I know one of the first places to look is the injection pump (stanodyne) but I had it rebuild less than a hundred hours ago. Should I be looking at the fuel pump or others places? The tractor runs and starts fine and almost no smoke. How can I isolate the problem rather than throwing parts at it? THANKS for your help!
JWalker
06-11-2014 16:23:58
 Re: 2440 making oil?????? in reply to Denny One, 06-11-2014 06:15:20
I have had the same problem in the past on a 2040. Check/change transfer pump. It worked for me, that was 10 years ago and no problems since.
DeltaRed
06-11-2014 06:38:33
Sorry to tell you that your new pump is the culprit.Shaft seal has failed.It may have been damaged during installation.
jdemaris
06-11-2014 06:37:42
My bet would be the injection pump. Being recently rebuilt has nothing to do with it. It's a matter of flipping or cutting one of the umbrella shaft-seals when putting the pump back on. VERY easy to do - even when an experienced Deere mechanic does the job.
CAS
06-11-2014 07:25:39
 Re: 2440 making oil?????? in reply to jdemaris, 06-11-2014 06:37:42
I am putting my money in John's post.
Tx Jim
06-11-2014 08:42:54
 Re: 2440 making oil?????? in reply to CAS, 06-11-2014 07:25:39
I'd recommend checking transfer pump for leakage before pulling inj pump!!!!!!!!
jdemaris
06-11-2014 09:59:53
 Re: 2440 making oil?????? in reply to Tx Jim, 06-11-2014 08:42:54
Depends on when the problem started. The fact that the pump was recently changed is a BIG reason to suspect the shaft-seals. Otherwise - it would be a crap-shoot.
Tx Jim
06-11-2014 10:08:15
 Re: 2440 making oil?????? in reply to jdemaris, 06-11-2014 09:59:53
I agree but checking transfer pump is way less time consuming than checking cup seals on an inj pump.
David G
06-11-2014 06:35:01
I would suspect a lift pump.
Copyright © 1997-2015 Yesterday's Tractor Co.
