Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Talk Discussion Forum
574 hyd problem
Mike3320
05-31-2014 18:32:38
Have 574 when facing down hill hyd won't pick up three point and outlets quit working on level seems fine drained fluid took off cover looks ok inside screen on filter is good took out both screws below filter they seem ok there was some metal on drain plug but not much. Is ther a screen inside tranny to keep fluid in one end or the other ???
jimb2
06-01-2014 08:16:18
 Re: 574 hyd problem in reply to Mike3320, 05-31-2014 18:32:38
Hi, probably the transfer pump is not working properly. It is supposed to keep the oil from pooling in the different sections of the transmission. Over fill by at least 5 gallons of Hy-Tran may help the problem.
JimB
ih_bug
05-31-2014 21:55:25
when you changed the oil did you put at least 7.5 imp gallons back in?
Mike3320
05-31-2014 20:31:08
I'm wondering about mcv valve and where it is
Jim Naden
06-01-2014 03:56:28
 Re: 574 hyd problem in reply to Mike3320, 05-31-2014 20:31:08
The filter is mounted on the MCV.
caterpillar guy
05-31-2014 19:27:13
If you changed the filter and cleaned the screen that is about it . Refill and check the oil level it could be low enough that the pump starves. The steering is the priority so that would work if it is only getting a small bit of oil. the same pump runs both the steering and hyraulics for couplers and 3pt. Is the draft lever all the way donw it can affect the 3pt not coming up. That would be the heavy light lever.
