TractorLinks.com
Tractor Talk Discussion Forum
Re: What large volume of water ?
Pops1532
05-01-2014 07:28:44
For a sprinkler system to be effective it needs to be the proper type for what the building is used for.
Most ag buildings would need a deluge system which require a large volume of water. A deluge system doesn't use the sprinklers that have a fuseable link like you mentioned. They use sprinklers that are always open, and a control valve that is triggered by heat detectors.
Even though the dry systems use the sprinklers with the fuseable links, they still require a large volume of water to be effective. Reference SMS's and Ken Macfarlane's posts.
RodInNS
05-01-2014 09:19:39
 Re: What large volume of water ? in reply to Pops1532, 05-01-2014 07:28:44
I think you're mistaken about what is required in terms of systems... Most I have seen are dry systems, in frozen buildings... with individually fused heads. Depending on local codes, it's quite acceptable.
Rod
Pops1532
05-01-2014 23:06:40
 Re: What large volume of water ? in reply to RodInNS, 05-01-2014 09:19:39
A dry system is the only option for most farm buildings because they're not heated. That doesn't mean they would be the most effective option.
The typical farm won't have a sufficient water supply for even a dry system.
RodInNS
05-02-2014 08:44:06
 Re: What large volume of water ? in reply to Pops1532, 05-01-2014 23:06:40
There's lots of systems installed in buildings that to not have municipal water systems. Local school has one... and they had a fire. It saved the building. That said, I do not know how it works in that building. I suspect it has a large header tank to supply the water.
Rod
