Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Talk Discussion Forum
Re: Chevy 454 lifter noise update
rustred
04-22-2014 21:59:25
you have a lifter bleeding down. myself I would be using 10-40 oil, not 5-30. that engine is running in an oven all covered up. 5-30 makes no sense.
that's me and what I do.
also as rusty says a valve adjustment would be good too. it can be done with engine not running as I prefer as not so messy with oil flying around. from zero lash then tighten 3/4 to 1 turn.
T in NE
04-23-2014 22:31:44
 Re: Chevy 454 lifter noise update in reply to rustred, 04-22-2014 21:59:25
The factory must not know much then, since he's now running what they recommended.
rustred
04-24-2014 20:15:18
 Re: Chevy 454 lifter noise update in reply to T in NE, 04-23-2014 22:31:44
you always believe factory? I know he is running what is "recommended" take notice of that word! under severe operation heavier oil is required. gotta be a little smarter than some engineers! that is the general rule and is not written in stone! I have used 10-30 and 10-40 oil right from new in a 2006 chev 3/4 ton and not one bit of problem. the factory recommened 5-30. in other gas engines I have used 20-50 Castrol oil with no engine problems either. if you want an engine to last you don't use 5-30 or 5-20 oil in 90 degree weather. they even told me my warranty wont be covered and I told them I wont need warranty with the oil I use. have never blown up an engine either in all my driving. I have also openend up a 1972 350 chev engine that used 20-50 castrol right from brand new with over 200,000 miles on it and you could still see the original hone marks in the cylinders. that's why I use Castrol oil for about the last 35 years or so. so I hope you read this smarazz, as I don't just post things out of thin air!
