Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Talk Discussion Forum
Re: driveway repair
showcrop
04-22-2014 19:28:46
Here in NH State spec road base gravel and crusher run are nearly the same thing and the terms are used interchangeably. However not all crusher run passes state spec because it will have too much of one sieve size aggregate and too much of another. So regular crusher run may need to be "doctored" a little to bring it to spec. I hauled many loads of state spec road base from a quarry whose invoice states at the bottom that the crusher run does not meet state spec. They just added back in some material of the right size to make it meet state spec. Now what you are calling gravel may be what we call washed stone here. Washed stone will not compact in years, whereas the road base crusher run gravel used on roads here will within a month of just regular car traffic compact to the hardness of concrete.
Rollie NE PA
04-23-2014 16:24:19
 Re: driveway repair in reply to showcrop, 04-22-2014 19:28:46
Showcrop, We are on the same page, just different terminalogy for the different classes of products.
PennDot 2A has some of the overburden mixed with the rock as it goes thru the crusher. It makes a very good road base material. Compaction is tested with a Nuclear Densometer.
Does your state use Superpave asphalt mix? I have mixed feelings about it.
showcrop
04-23-2014 17:43:55
 Re: driveway repair in reply to Rollie NE PA, 04-23-2014 16:24:19
I am not familiar with that. I hauled about twelve loads of 3/4 base on Monday and it looked the same as it ever has. What is different about it?
