TractorLinks.com
Tractor Talk Discussion Forum
Re: OT Dish Network Receiver
spacecadet9
04-21-2014 23:50:29
John T said: (quoted from post at 18:39:09 04/21/14) Is it possible for an older Receiver (mines a 625 with several years on it) to go bad and cause there to be a weak signal so I can buy month to month and shop around WITH NO LONG TERM CONTRACT John T Electrical but NOT much of an Electronics Enginner at my old age
A simple answer: Yes! Resistors and capacitors can change values as they age, and electrolytic caps can leak. Or, solder connections can crack.
Since you've eliminated the coax, switch, LNBF, and alignment: Have you checked the DC voltage feeding to the LNBF? You should have either 13 VDC or 18 VDC measured between the center conductor and the shield. That voltage powers the LNBF and switches the LNBF polarity between LHCP and RHCP. The 625 is dual tuner, do both tuners have low signal? Have you connected the receiver and a TV outside at the dish?
You can pickup a replacement DVR-625 for $65 at solidsignal.com
I understand why you prefer owning rather than 'leasing' with a multi-year commitment.
This post was edited by spacecadet9 at 23:51:51 04/21/14 2 times.
John T
04-22-2014 05:07:01
 Re: OT Dish Network Receiver in reply to spacecadet9, 04-21-2014 23:50:29
"The 625 is dual tuner, do both tuners have low signal? Have you connected the receiver and a TV outside at the dish?"
YES Both 110 and 119 have weak signals, 20 to 50 max DESPITE no blockage,,,,,,Despite perfect aiming and tweaking using a signal strength meter at the dish,,,,,,,,despite a new LNB,,,,,,,,new and tried different 25 ft cables from Antenna to Receiver
I can buy a new HD Receiver in the box on Flea Bay for around a hundred bucks so Ima thinkin its about time to go ahead and upgrade as my 625 is pretty olddddddddddddddd.
THANKS
John T
spacecadet9
04-22-2014 09:16:08
 Re: OT Dish Network Receiver in reply to John T, 04-22-2014 05:07:01
Quoting Removed, click Modern View to seeBut, do BOTH TUNERShave low signal? "The Dish Network 625 satellite receiver contains 2 individual tuners in one box. These Tuners are designated TV1 and TV2."
We are currently running 722K receiver that I add the OTA tuner module. HD is nice, sometimes. When we upgraded our old Dish 500 pizza pan had to be upgraded also. Not only to add the 3rd satellite, but the switching technology had changed also. I don't know which dish you are currently using, just do some research. "Subscribers west of Chicago use Dish 1000.2 antennas aimed at the 110W, 119W, and 129W orbital locations (referred to as the western arc). Subscribers east of Chicago use Dish 1000.4 antennas aimed at the 61.5W, 72W and 77W oribital locations (referred to as the eastern arc).
If buying used from an individual do you due diligence concerning clear ownership and billing.
To appease some readers: I'm in the process of acquiring a Farmall 450 motor to drop into my M. (Tractor related:-)
John T
04-22-2014 12:09:49
 Re: OT Dish Network Receiver in reply to spacecadet9, 04-22-2014 09:16:08
On my old Dish 625 with Dish Pro and 2 Eyes LNB 500 Pizza Pan in South Central Indiana, I'm on 110 and 119 yet that's just slightly East of Chicago.
I will study before I buy a new HD 1000 series Pizza Pan with the 3 eyes to get the right one
THANKS FOR THE INFO
John T
