Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Talk Discussion Forum
Re: OT: '98 LeSabre sometimes won't start
john in nebraska
04-13-2014 08:18:56
Try starting it in neutral, see if that makes a difference, if it does, it is possibly the neutral safety switch. Double check the battery post connections, intermittent no start I usually trace back to the battery. Also because a battery is fresh, may not mean it is ok. The other thing to check is if the cable on the starter is tight, takes a tight connection to pass 400 amperes.
michael soldan
04-13-2014 09:58:42
 Re: OT: '98 LeSabre sometimes won't start in reply to john in nebraska, 04-13-2014 08:18:56
I'm with you john,and I've seen poor ground cause similar problems in intermittent starting. Yes there are or may be other reasons but checking ground and having clean terminals is an easy start point in figuring out what is wrong.
Copyright © 1997-2015 Yesterday's Tractor Co.
