Yesterday's Tractor Co.
Shop Now View Cart
Tractor Talk Discussion Forum
Re: Stuck piston and shaking front end!
El Toro
04-13-2014 07:31:59
If your tractor is outside and you're away from any building I would set that diesel fuel on fire
on that last piston. The heat should free the piston. You may need a sleeve puller to remove the sleeve using a puck. Remove anything flammable.
I would check the front wheel bearings to see if they're worn from lack of grease. Most auto parts stores should have new bearings and races.
Here's a picture of a sleeve puller made by Keith. Hal
04-13-2014 07:36:10
 Re: Stuck piston and shaking front end! in reply to El Toro, 04-13-2014 07:31:59
Thanks i will pull it outside and try it!
