TractorLinks.com
Tractor Talk Discussion Forum
rusted fenders
ricb
03-24-2014 15:10:04
The 7800 has come in the shop for various repairs. I would like to replace the fenders as they have rusted through and look extremely ratty. This is a high houred tractor.(19,000 hrs) it still gets plenty of use and I would like to spiff it up a bit. I priced the fenders through the dealer $428 per side. Is there any other options out there?
Ralphwd45
03-25-2014 00:00:03
 Re: rusted fenders in reply to ricb, 03-24-2014 15:10:04
Remove the fenders, sand blast both sides. paint on a coat of epoxy resin, lay out a roll of boat fiberglass. Paint on more resin. lay on more matting, and resin. till you have at least 2 layers of mat on each side of the original metal. Sand and paint, and re install fenders. Boat glass will flex and not crack. I done the body (floor pan) on my 72 jeep commando, this way back in 98, and It is still good
Massey farmer
03-25-2014 01:49:06
 Re: rusted fenders in reply to Ralphwd45, 03-25-2014 00:00:03
That's a pretty good idea. What does the resign and Matt cost do you think?
the flying belgian
03-24-2014 20:14:55
I don't think that price sounds all that bad. I have repaired some for customers in my metal fab shop. Don't take long to get $250 in it and then it still needs to be painted. I assume the new ones come painted.
mab570diesel
03-24-2014 16:26:43
 Re: rusted fenders in reply to DeltaRed, 03-24-2014 15:10:04
i think it would be ok but i would guess it depends on how hot the fire was and how thick the metal is.
samn40
03-24-2014 16:08:39
Over our side of the Big Pond the 7800 had plastic fenders for that very reason!...............Sam
Janicholson
03-24-2014 15:21:16
That price isn"t too bad. Were it me I would put the money (and more) into new rear tires.
Flat conveyor belting cut to look like a mudflap triangle bolted with small pan head SS machine screws around the edges would work. Follow the contours and it will be just fine. round the edges so it looks like it was made not slapped on. Jim
mab570diesel
03-24-2014 15:55:36
 Re: rusted fenders in reply to Janicholson, 03-24-2014 15:21:16
try to find a set at the salvage yard.
ricb
03-24-2014 16:13:08
 Re: rusted fenders in reply to mab570diesel, 03-24-2014 15:55:36
Any of these tractors at the salvage yard have been burned. Will they be OK if they are painted or will they be warped from the heat?
jterry
03-24-2014 15:14:52
are you any good at mig welding, place thin gauge steel sheeting under it, a little bondo and some paint. if and only if for equipment used in the field. If it is a customers ask if they wanted repaired or replaced
