Yesterday's Tractor Co. The Right Parts, Right Away
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Talk Discussion Forum
There is no justice
Erik Ks Farmer
02-10-2014 14:59:43
199.241.240.11
In the world. Saturday morning at 6am the alternator went out in my pickup 10 miles from home. Good friend jumped me 3 times to get it town. Replaced the alt, broke off the plastic overflow and the radiator. Drilled it out, tapped it and replaced with brass. Did chores and went home about 130. Went back out to do evening chores and it wasn't charging. After cleaning all the terminals and reading horror stories on you tube I yanked the hot wire off the batt and it died. Took it in to the big city since the local auto parts was closed and sure enough tested 12.3. Rated for 14.6. Replaced it again. Fast forward to Monday, installed replacement starter on 1105 Massey, she fired up. Ran about 5 minutes and gelled up....can we fast forward to spring?
[Reply]   [No Email]
Nancy Howell
02-11-2014 09:14:54
144.162.49.190
 Re: There is no justice in reply to Erik Ks Farmer, 02-10-2014 14:59:43
I second that motion!!
[Reply]  [No Email]
jeffcat
02-10-2014 18:15:29
173.72.26.60
The next thing to happen is plenty of MUD!!
[Reply]  [No Email]
donjr
02-10-2014 17:51:01
71.246.90.173
So what did Wrigley do? Cheer you onward???
[Reply]  [No Email]
Pete in MD
02-10-2014 20:43:41
71.245.164.148
 Re: There is no justice in reply to donjr, 02-10-2014 17:51:01
Doesn't Wrigley hang out with Bill on the Farm?
Haven't seen him on here in a long time.
[Reply]  [No Email]
Erik Ks Farmer
02-11-2014 03:59:18
199.241.240.11
 Re: There is no justice in reply to Pete in MD, 02-10-2014 20:43:41
X2, yes wrigley is Bill's dog. This is Tin.
[Reply]  [No Email]
dzc3
02-10-2014 17:31:14
166.181.3.107
Yep and We would not change our place in the World for anywhere else. People ask me now that you are kinda retired where are you going to go! Heck I am where I want to be !!
[Reply]  [No Email]
Diydave
02-10-2014 17:03:38
96.244.161.47
Never yank any terminal off a battery, when an alternator is in the system. You blew the diodes out when you did that...
[Reply]  [No Email]
Joe Scribner
02-10-2014 16:31:43
23.29.217.123
I'm in agreement with all you guys. Hate it when things snowball like that. Took the back cover off the walk behind snowblower to replace sheared cotter pin in the clutch rod. Found a bad crossshaft bearing. Looked a bit further and saw the auger drive belt coming apart so split the blower to replace. Then found the auger drive pulley was loose and wallowed out on the impeller shaft. Noisy idler bearings, worn out impeller shaft bearings. You get the picture. Machine is completely tore apart and have lots of new pieces ordered. Come on Spring, hurry the heck up !!
[Reply]  [No Email]
VicS
02-10-2014 16:16:47
70.195.65.152
Know what you mean. Drove the backhoe over a something and bent the oil pan up and the oil pickup tube. Think motor is alright. But it has started leaking oil nearly everywhere. Spring better hurry up!
[Reply]  [No Email]
rc grey
02-10-2014 16:02:56
67.234.64.3
Momma said cheer up son things could be worse so I cheered up and shur nuf things got worse.
[Reply]  [No Email]
notjustair
02-10-2014 15:52:04
174.229.65.162
I'm out in this nasty cold trying to get tractors ready for spring. I can't figure out how things that didn't leak in October are leaking now when they haven't been run. I've had about the same luck with machinery lately, but no charging issues. Those about push me over the edge.
[Reply]  [No Email]
Just Another Old Geezer
02-10-2014 15:26:02
216.105.208.2
let's see the 666 is down for an engine overhaul so I don't have a tractor with tire chains for hauling Manure. The 986 is down with hydraulic issues so I'm hauling manure with a borough 1066. because I have no tractor with chains I have to stack all the manure. The barn cleaner is frozen daily. The silo unloader is frozen twice a week. The augar pit is frozen twice a week.I had to put a heater in the well pit to keep the pipes from freezing, never had to do that before. the Kawasaki diesel mule is gelling up so when I need to split firewood I have to move the splitter from the garage over to the house by hand, or push it with the Bobcat. I am running out of places to pile snow. I would be glad to trade problems with you.
[Reply]  [No Email]
nybadlybent
02-10-2014 16:44:09
74.79.159.227
 Re: There is no justice in reply to Just Another Old Geezer, 02-10-2014 15:26:02
Sounds like you are are on your own 10 yard line, 4th down and 40 to go for a first down. I suggest that you punt.
OR hang in there and do the best that you can. We all have trying times and get discouraged but we keep going somehow. In a couple of months it will be all forgotten and we will have a new set of problems.
REMEMBER, when the going gets tough, the tough QUIT.
[Reply]  [No Email]
02-10-2014 22:21:32
216.105.208.2
 Re: There is no justice in reply to nybadlybent, 02-10-2014 16:44:09
I have always said that there is a VERY FINE line between stone cold determination and not having brains enough to know when you are beaten.Right now I am so far over that line I can't even see it anymore..
[Reply]  [No Email]
mab570diesel
02-10-2014 15:12:07
76.6.162.148
 Re: There is no justice in reply to David G, 02-10-2014 14:59:43
ya when it rains it pours
[Reply]  [No Email]
Old Popper
02-10-2014 15:09:59
216.51.202.134
Sounds like "Murphy" found you. I've been sitting pretty still in this cold weather, so he must have got bored with me and jumped over to your place.....
[Reply]  [No Email]
Royse
02-10-2014 15:04:03
69.36.49.186
Ah spring.
When we use much more equipment with a chance of breaking! LOL
Hope things start looking up for ya Erik.
[Reply]  [No Email]
Animal
02-10-2014 15:13:26
76.4.183.82
 Re: There is no justice in reply to Royse, 02-10-2014 15:04:03
You poor b@stard! Let me guess, it was an Oreilly rebuild.
[Reply]  [No Email]
Erik Ks Farmer
02-10-2014 15:19:56
199.241.240.11
 Re: There is no justice in reply to Animal, 02-10-2014 15:13:26
Haha, no step up in the world. NAPA, replaced with Advanced
[Reply]  [No Email]
kjSeil
02-10-2014 16:55:29
75.81.237.206
 Re: There is no justice in reply to Erik Ks Farmer, 02-10-2014 15:19:56
went thru 2 in an autozone parking lot last summer to get a good one, 3rd is a charm ya know
[Reply]  [No Email]
johnlobb
02-10-2014 17:55:32
67.142.181.20
 Re: There is no justice in reply to kjSeil, 02-10-2014 16:55:29
Years ago, living in Bay City, MI, I had a GMC Safari minivan and went through 8 alternators from Murreys (since bought out by O"Reillys)and got really good at replacing them, all rebuilt. I finally told them I want a Delco, enough is enough, never any trouble with the alternator after that.I had plenty of trouble dealing with the rear axle seals that would blow out like clockwork every 50,000 miles, the vent was not plugged, never did find out what was the cause. Then the rear brake shoes would be ruined when that happened.
[Reply]  [No Email]
Jerrybigrig
02-10-2014 19:03:04
66.87.90.200
 Re: There is no justice in reply to johnlobb, 02-10-2014 17:55:32
Just think when it finally warms up w all this moisture around we will be swatting flys and mosquitoes by the thousands haaaaaa
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
