Yesterday's Tractor Co. Trusted Parts Supplier since 1995
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Talk Discussion Forum
Howes
David G
02-10-2014 14:31:33
205.215.206.18
The store was out of power services, so I bought a jug of Howes. It is going to be -22 in the morning and I have a two hour drive.
I am going to be really mad at you guys if I gel up.
[Reply]   [No Email]
Tramway Guy
02-10-2014 17:59:11
64.134.127.204
 Re: Howes in reply to David G, 02-10-2014 14:31:33
I mix with undyed kerosene, a little expensive, but works good.
[Reply]  [No Email]
dzc3
02-10-2014 17:38:53
166.181.3.19
I should have added get a cardboard box(a big one) unfold it, now open your hood place it on the back side of the grill shut the hood fast before it can fall down. In extreme cold your engine will not over heat, the card board is still about six inches away from the Rad. and lots of air can get around it. I have done this many times. If the engine gets warm on a hill turn heater fan on high.
[Reply]  [No Email]
dzc3
02-10-2014 17:34:11
166.181.3.10
Pure chemicals will gel just keep the bottle warm add pour it in when you fill or add it along the way adding more will not hurt anything regardless of the brand.
[Reply]  [No Email]
tomNE
02-10-2014 16:35:43
70.197.209.170
snake oil = a good description of Howe's. get some number 1 fuel into it and change fuel filter if you didn't last fall!
[Reply]  [No Email]
Mike Aylward
02-10-2014 16:24:34
209.152.135.126
On one brand of fuel conditioner I recently bought (not Howes) it mentioned on the label that it had to be mixed with fuel that had a temperature of at least 32 degrees. Apparently it does not mix well under that temperature. Is this the reason that some fuel conditioners work sometime and then fail miserably the next? Mike
[Reply]  [No Email]
Mark - IN.
02-10-2014 16:19:55
98.215.76.204
Well, that's a good question. I've never had either PS or Howes let me down. Never once. But, there was a tank full once when I didn't add either, and the temps seriously nose dived and I found myself limping into a truck stop to get some PS 9-1-1 to open my waxed injectors and it did the trick. And therein lies my question. The PS 9-1-1 didn't hurt anything, so I have to wonder with extreme cold, can you mix it in with your fuel that has already been treated with either PS or Howes as harmless insurance. Anyone know?
By the way, I use PS or Howes all year long, every tankful, trucks and tractors ever since the gel up, and I've not had a problem since. But...anyone know in the cases of extreme cold, if you aren't running No. 1 diesel, can you add PS 9-1-1 to make up the difference? Anyone know?
Thanks.
Mark
[Reply]  [No Email]
David G
02-10-2014 16:03:32
205.215.206.18
Fuel is blended to -10, so should be OK.
[Reply]  [No Email]
T in NE
02-10-2014 19:22:00
75.239.79.229
 Re: Howes in reply to David G, 02-10-2014 16:03:32
Depends on where you are. There"s 2 co-ops and a truckstop around here where you can get fuel. The one co-op blends 70/30, when I gelled last winter they said I had other problems because they had blended it 70/30, and they would like to blend it heavier but their supplier wouldn't let them. And they had mixed one batch of 70/30 and dumped it in the storage tank when the forecast got cold. The other co-op runs 50/50, and the truck stop was built and is run by guys from Michigan so they just dump in the proper amount of a #1300/barrel additive.
I ran in Michigan a lot up as far as where they came from and never saw -10, doubt I saw 0, let alone -20.
[Reply]  [No Email]
S2710
02-10-2014 15:58:23
207.190.76.146
David if you buy your fuel from a reliable place that says they have winter blend, I would not worry. If I was worried I would dump a quart of gas in the tank and go.
Bob
[Reply]  [No Email]
Lazy WP
02-10-2014 15:52:02
67.142.168.27
Howes is all I run, along with straight #2, in all my tractors, skidsteer, and 06 Dodge. Other then the skidsteer, I have never gelled. The skidsteer must have Ice in it, cause I have to blow the line out to make it run, below 0.
[Reply]  [No Email]
mjbrown
02-10-2014 15:07:24
70.209.128.153
Howe's failed me this winter for the first time.
[Reply]  [No Email]
SD Pete
02-10-2014 15:02:47
24.230.163.196
Better get some number 1 fuel in that thing.
[Reply]  [No Email]
Allan In NE
02-10-2014 15:26:16
199.47.66.57
 Re: Howes in reply to SD Pete, 02-10-2014 15:02:47
Amen to that!!
Snake oil ain't-a-gonna do it!
Allan
[Reply]  [No Email]
in-too-deep
02-10-2014 14:49:21
64.235.94.33
Howe's itself will gel up at -22. It might work when mixed with diesel, but I've seen it get all cloudy and thick. #1 fuel is the best defense.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
