In a perfect world all IH tractors would use HyTran, JD's - JD Trans fluid, Ford's- Ford Trans fluid, etc. I agree that using the manufactures brand is the safest bet when it comes to the different oils & Fluids for that manufactures tractor. I also agree that HYTran is a very good fluid! Its very common to move the plow, disk, harvester, planter and other hydraulically operated implements from tractor to tractor - International to John Deer to Ford to Oliver. So, at the end of the season what oil is in what tractor? My guess is some of the oil from every tractor that shared any implement. The fluid used on my dad's farm was HYTran most of the time. But on occasion we used other brands (Wolf's Head comes to mind as one) that specified that it met or exceeded the IH Hytran Spec, Dextron II Spec, Dextron III spec, Mercon Spec, and John Deere's Spec. Also, I do remember the white 5 gal HYTran bucket from IH that said it was Dextron II in the pre Tenneco days. I've got to believe that once an oil company took control of IH that it had a good business reason to discourage the owners from using anything but their oil. Although Bill is correct in recommending HYTran (Tenneco's marketing materials worked here) there are alternatives that meet or exceed the HYTran spec. Of interest, Peereless or Eaton manufactured a large percentage of the HYDRO unit's for the Cub Cadet in the IH years. Peereless and Eaton also manufactured HYDRO units for other Garden Tractor manufactures who I'm sure do not promote the exclusive use of HYTran. : : Hy-Tran is the only transmission fluid to use!! : Hy-tran is not even close : : to Dextron. No other trans. fluid meets all Hy-tran : : specs. The big one is water retention ability, Hy-tran : : will take up to 1 percent which prevents rusting and : : sludging. Some of these fluids have zinc which is : : not good for the special brass metals in the hydro. : : These Hydros are very durable and last for ever if : : you use Hy-tran.; no other fluid is worth testing since : : parts are a lot more expensive than Hy-tran. : I personally think a transmissions worst enemy is water! More bearings go from rust and flaking bearings. The dirt is not good, but generally has destroyed far fewer gears, bearings, and hyd pumps than uncontrolled moisture. : I've overhauled a number of larger Hydro tractor transmissions, and always liked doing it, because the Hytran on my hands would make my skin as soft as my wife's and the dirt and oil would be lifted out of the cracks in surface skin. : I've seen Hydro's destroyed in very short times by oils that had a crafty salesman, but not even a fraction of the quality of Hytran. : Hytran is a 10wt. hydraulic transmission fluid, built to control moisture and bubbles in hydraulics. I've never seen one that will do better. A farmer with good maintenance habits can get good service from his Hydro as his reward. : Never use a heavier oil in a Hydro. It will cause much more heat! A hydro has much higher oil pressures, and this can really cas foaming in some lesser oils! : You could buy Hytran from the CASE-IH dealership where I work, for $5 a gallon. They buy it in a bigger bulk tank, for the better price.
