rick n ohio
i am having a problem lifting round bales high enough off the ground to load them on a round bale carrier that hauls six bales with my newholland t4020 rated 64 hp tractor.i can use the same bale spear on my little mf-35 and lift them probably a foot higher with this much smaller tracor and load the wagon with ease.i tried adjusting the top link but still will not get them high enough.i even adjusted the lift arms to there highest position with still not enough height.it is going up to its highest limit.only thing i can figure is the lift arms on the little mf must be shorter making them raise higher ;any you guys ever experience this problem
RICK
RICK
