Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Talk Discussion Forum
? about Direct TV
Farmallstrong
01-19-2014 16:09:43
We have Direct TV & it is locking up/or freezing the picture. This happens sometime 6to 10 times a day. At first it was only doing it on one channel, but now it's doing it on two channels. If you change channels and then go back to the frozen channel, you will either correct it or get a black screen. It affects the picture and the voice. I have checked all connections and they are all tight, and I have reset the box by pushing the red reset button on three separate occasions. I have also unplugged the unit from the electric in hopes that it would reset that way. Any help would be appreciated. This is tractor related because I watch RFD TV. Thank you.
John M
01-20-2014 03:28:44
 Re: ? about Direct TV in reply to Farmallstrong, 01-19-2014 16:09:43
Push the red button - Wow, hadn"t seen that receiver in YEARS! Must be an old one. It may be time for a new one, but it does sound like your dish has moved just enough to knock it out of whack. Just call them! Very good to deal with, unlike Dish. My buddy has been waiting 2 weeks on Dish to come install his. Hes thinking of calling and cancelling.
bobs old iron
01-19-2014 22:16:28
even though i have dish, probably same thing, when i have it on the h-d channel, it freezes up, bring up program schedule, realizing it, i change to reg channel, no problem, because i don't have a hd-tv...
Waltdavies
01-19-2014 19:49:01
Mine was doing that they came out when he touched the pickup it fell right off so he put up a new dish told some of the older ones had a week spot there.
Walt
J.Wondergem
01-19-2014 17:47:24
Just call them, they'll come out and check it out for you. No charge.
MarkB_MI
01-19-2014 17:34:42
Your antenna needs to be aimed. My antenna is mounted on a wooden post; I think the post twists as humidity changes, so I have to re-aim my antenna a couple of time each year.
This isn't hard to do. Hit the "Menu" button on your controller, then follow the menus to get to Setup. Pick "Satellite", then "View Signal Strength". It will go through the different transponders and report signal strength, which should be in the high nineties. When you hit a transponder with a low reading, pick "Signal Meters". It will stop on that transponder and give you a visual and audio indication of signal strength. Now you just have to adjust the antenna until you get the best possible reading.
It's best if you have a helper in the house to report the readings, but I've done it myself by calling my cell phone from the landline phone, and listening to the audio strength over the phone. You're trying to get the audio indicator to cheep as rapidly as possible. Adjust both azimuth and elevation, going back and forth. The adjustments may interact.
It's a good idea to mark your original position with a pencil or Sharpie before you start, as it's easy to knock the adjustment way out of whack once you loosen the locknuts.
js305
01-19-2014 17:32:42
Check the menu and navigate to the setup part where the antenna strength is located. I don't know exactly where it is but it will tell you if the dish is aimed right. That is what it sounds like to me.
And, like the other poster said, make sure there isn't anything in front of the dish. I had bird droppings all over mine one time. Right on the LNB. Had to get up there and scrub it off.
gene bender
01-19-2014 17:30:41
Have you called them they have great service and your stuff from them is covered by them. They will replace.
dpendzic
01-19-2014 17:25:15
call direct tv--they can test your receiver and check out the strength of your signal--- and can also reboot--they fixed mine from doing that
Chris English
01-19-2014 17:18:17
Ours did the same thing recently. I unplugged the dvr for a few seconds and it hasnt happened again. Oh by the way, we have Dish network. A friend said the dvr is probably dying
old
01-19-2014 16:37:27
Turn it off then pull the card out of the receiver then stick the card back in. Turn it back on and see if that helps. Some times they need to be not only reset but programing card pulled out and then back in to fix that type of thing
rrlund
01-19-2014 16:22:11
Mine did that all summer. I guess it was the leaves on the trees just like the tech said it was when I called to complain back in about June.
That said,we had a terrible time with it about six or seven years ago doing the same thing. Took several calls to get through to somebody who'd listen,but apparently they can pull up on a screen and see exactly what you're seeing on yours. When the woman did that,she was apologizing all over the place. She sent out a tech and they installed all new equipment. New dish,cables,box,remote,the works,no charge and they threw in free HBO,STARS and ENCORE for three months.
