Yesterday's Tractor Co. New Parts for Old Tractors
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Talk Discussion Forum
New Holland 492 Haybine
olliekid
01-19-2014 12:45:36
99.164.60.18
Dad and I just purchased a New Holland 492 haybine. We seemed to have got a decent deal on it. Wondering what HP you would recommend using on it. We have a 35hp JD 830 3 cylinder, or we might use it on the Oliver 1655 diesel if need be.
Wondering if anyone can tell me what year it is. The serial number is:
895606
Thanks for the input in advance. It sure was not fun driving it home! Darn thing stuck out real wide! Can't wait to try it out in the spring.
[Reply]   [No Email]
GordoSD
01-20-2014 08:53:45
216.106.251.211
 Re: New Holland 492 Haybine in reply to olliekid, 01-19-2014 12:45:36
Now is the time to run it a little and listen to the gearbox. If it clatters bad it needs rebuilt. Check the guards. New, gap is about.150. Anything over .275 toss em. Check the register. When sickle is full right it should be centered with guard. How are the sections. New sickle needed? Buy one with bolts and serrated. When rejuvenated sickle is in, get a .025 feeler gauge. Bend all the guards until you have this between the bottom of the sections and the guards. Check your oil level, give her a good greasing and go make hay.
[Reply]  [No Email]
showcrop
01-19-2014 19:17:59
75.67.231.80
Does either have a flat deck? I like to be able to cross my legs when I am out for awhile.
[Reply]  [No Email]
JD Seller
01-19-2014 14:59:04
208.126.196.144
Your NH 492 is a 1996 model. It is a 9 foot 2 inch cut. In light hay the JD 830 will pull it but in heavy hay you will need the Oliver 1655. It also depends on how fast you want to mow. To keep a fairly fast ground speed in heavy hay will take more horsepower than the JD 830 has.
Had a friend that had a NH 488 haybine. He tried to run it with his WD 45 and had sickle problems all of the time. The ground speed was wrong for the PTO speed. IT was wedging the sickle full and then having to shear it packed full. He switched to his AC 185 and the sickle issues went away. This was in waist high thick timothy and heavy alfalfa.
IF your hay is thinner then you may get along with a smaller tractor but I would not risk it myself. You need a tractor with the HP to hit a thick spot and pull through without bogging down.
Also like rrlund pointed out the Oliver is a lot nicer tractor to ride across a field than the smaller JD 830 utility tractor.
[Reply]  [No Email]
NY 986
01-19-2014 15:28:44
67.142.182.23
 Re: New Holland 492 Haybine in reply to JD Seller, 01-19-2014 14:59:04
Yeah, I think I would want at least 50 PTO HP in 3 ton (100+ small square bales) hay.
[Reply]  [No Email]
rrlund
01-19-2014 14:24:29
162.250.26.204
I'd sooner sit on that 1655 all day than that little Deere.
[Reply]  [No Email]
farmeroz
01-19-2014 13:29:08
71.185.124.187
http://www.messicks.com/cnhmodels/MowerConditioner.aspx Try Messicks link for models and years.
[Reply]  [No Email]
old
01-19-2014 13:06:00
209.86.226.32
I pull my NH 460 9 foot cut hay-bine with my Oliver 77 and it plays with it so that JD should handle it just fine on all but a steep hill that is
[Reply]  [No Email]
JayinNY
01-19-2014 13:05:51
198.228.200.173
I've got a 489 that I run on a 52 hp Ford. If I remember correctly, the manual says 35hp minimum. But I could be wrong,
[Reply]  [No Email]
MN Scott
01-19-2014 12:56:49
184.158.4.227
Dad had one back in the day. Pulled it with a Farmall Super H. No problems, lots of hills too.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
