Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Talk Discussion Forum
Re: 3020 sitting on its own
JD Seller
01-14-2014 17:05:16
RBnSC:
You should make a flat iron bracket, like the double front weight bracket has, that would bolt to the outside of your frame rail using the center holes. This would help strengthen the frame a lot. A piece of 1/2 x 4 inch flat with the holes drilled in the center would help a lot.
RBnSC
01-14-2014 17:40:44
 Re: 3020 sitting on its own in reply to JD Seller, 01-14-2014 17:05:16
Good idea. I take it that you don't have much faith in my welding..:)
Ron
Bob Bancroft
01-14-2014 18:33:10
 Re: 3020 sitting on its own in reply to RBnSC, 01-14-2014 17:40:44
He may be thinking that the joint is in a very vulnerable spot. I was surprised when I noticed the side frame on my 2520 twisting a little with a side mounted sickle bar mower hanging on it! There is no give in the side frame of any of the older AC's I've had the same mower on.
Copyright © 1997-2015 Yesterday's Tractor Co.
