Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Talk Discussion Forum
2n fel
Kelly boy
01-14-2014 10:36:37
198.228.200.19
I have a '47 ford 2n and have a wagner fel for it. Jest wondering the best way to cobble up a pump,tank,and valves. I understand i can run it off the 3pt pump but don't want to go that route. Spare me the "n tractor is usless with a fel" speel. it is all i have and it will be primarilly used to load/unload my sawmill. Any info will be greatly appreciated. Thanks.
[Reply]   [No Email]
Royse
01-15-2014 20:18:42
69.36.49.186
 Re: 2n fel in reply to Kelly boy, 01-14-2014 10:36:37
Mine is not one of TOH's kits, but that would be a good way to go.
Give him a call. Even if you don't buy a kit, he can give you an
idea of what the part numbers would be and what is involved.
[Reply]  [No Email]
Royse
01-15-2014 10:28:32
69.36.49.186
Yes, I was referring to the Dearborn style, or the old Ferguson one.
It might work ok for his intended use if he's comfortable with it.
Keep in mind that the Ford N's had non-live hydraulics so the
clutch had to be engaged and the PTO running to use the 3 pt.
They also have zero external hydraulics, so a cylinder is not an
option unless you do some modifications.
A front mounted pump like many FEL's used would be one way.
[Reply]  [No Email]
Royse
01-15-2014 04:49:22
69.36.49.186
Ya, it's too soft and has a tendency to collapse shut too.
It was only on there for testing after I drug the tractor
home, got the motor freed up and got it running.
[Reply]  [No Email]
Royse
01-14-2014 20:05:43
69.36.49.186
"just wondered if you have given any thought to a rear end loader on the 3 point?"
ih_bug, I know you weren't replying to me, but I have thought about
them. The originals are hard to come by and expensive if you do.
They are also a trip bucket, not nearly as useful as a fully hydraulic loader.
They won't lift as high and it's harder to see what you're doing.
It would be neat to have as a novelty, but for actual use I would pass.
[Reply]  [No Email]
ih_bug
01-15-2014 10:16:11
216.104.126.137
 Re: 2n fel in reply to Royse, 01-14-2014 20:05:43
by originals do you mean the dearborn? I think there was a video on you tube but cant seem to find it right now. I would like to see one of those up close.
there are lots of trip bucket front end loaders too and some hydraulic rear end loaders. I know a 2n wont take a very big rear end without the wheels coming off the ground.
He said it was for use around a sawmill moving logs a trip bucket will work great in that application as will a rear end loader ,easier to steer comes off fast to leave tractor free for other things and the lifting weight is on the big drive wheels where it should be.
I dont agree with you on not being able to see as well I think its just the opposite but that depends a lot on the design of the loader. I can see A variation on the design of this bale spear being real handy.
http://www.youtube.com/watch?v=MH0o8uJlxYo
put a cylinder in where he has the top link lose the top spear should work good around a sawmill . light weight and cheap to build.
[Reply]  [No Email]
ih_bug
01-14-2014 19:19:02
67.58.222.152
[Reply]  [No Email]
DeltaRed
01-14-2014 17:37:49
67.40.59.83
Kelly,I'll spare the "speel"....Ns are great little tractors,I love em!But they can get a bit light in the rear end.It will help tremendously to load the rear with fluid(that's the 'secret' to an N).A heavy wt on the three point will be a big help in that department as well.As was said go with a 'live' pump on the crankshaft.
[Reply]  [No Email]
Royse
01-14-2014 15:54:32
69.36.49.186
As the others said, a stinger pump driven off the crankshaft.
Shaft pump goes right through the hand crank hole in the grill.
That gives you live hydraulics for the loader.
You do have to change the crank pulley for the pump to hook to,
and that requires detaching the front end and moving forward a bit.
I actually just detached the steering and radius rod on one side
and swung it around out of my way.
This one happens to be on my Jubilee. I also had one on a 9N, same idea.
You can make your own mounts or use a bumper like they did here.
Note the damaged dogleg, radiator and missing grill. Done before I owned it.
Some front end protection is a good idea too as on the 9N.
[Reply]  [No Email]
kelly boy
01-15-2014 18:14:38
66.30.52.200
 Re: 2n fel in reply to Royse, 01-14-2014 15:54:32
That's what I'm talking about! thanks for the pics. where can I find that pump and shaft? Is it one of The Old Hokie's kits?
[Reply]  [No Email]
Stick welding
01-14-2014 22:47:51
96.53.210.246
Royse, you should change that clear braided suction line to a proper Hyd. suction line. I've never seen a clear hose rated for hydraulics/oil use.
[Reply]  [No Email]
old
01-14-2014 11:11:34
209.86.226.27
What you need is the mount for the front driven pump and a drive hook up and the correct pulley so the drive hub will bolt on. I have a 8N with both loader and back hoe that uses a front driven hyd pump
[Reply]  [No Email]
kelly boy
01-15-2014 17:59:20
66.30.52.200
 Re: 2n fel in reply to old, 01-14-2014 11:11:34
Nice, I hope to get a backhoe for it someday. Thanks for the hope.
[Reply]  [No Email]
HCooke
01-14-2014 10:56:59
70.195.64.81
Go to the N Board on YT and you will get a lot more advise than here. There is a guy there, TOH, who has a lot of good ideas on N hydraulics.
[Reply]  [No Email]
bobs old iron
01-14-2014 10:45:28
63.224.79.70
some run a pto pump off the front of engine, thus loosing hand crank starting, a least you have consist pump power, running off pto on rear [if app] you loose power when clutch is pressed
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
