TractorLinks.com
Tractor Talk Discussion Forum
Re: Gas Tractor and GPS?
in-too-deep
01-13-2014 15:27:04
Exactly. You'd record a boundary around the field, and it'll calcualte the acreage of everything inside that field. You can also record that same boundary as an A-B line and it will automatically steer through the curves, although there's fewer curves where you farm :). The, you'd set up your main line to work the field and save it. Can move that data to a USB stick and load it into other GPS equipment. Down Under is right, though, it can be much more complicated if you'd like it to be. Honestly, Allan, with as much as you like playing with electronics, I thought you'd be keen on the idea : )
Allan In NE
01-13-2014 15:51:09
 Re: Gas Tractor and GPS? in reply to in-too-deep, 01-13-2014 15:27:04
We're talking what? $5K?
Thanks for the info, by the way.
Allan
IaGary
01-13-2014 16:51:01
 Re: Gas Tractor and GPS? in reply to Allan In NE, 01-13-2014 15:51:09
Cruser light bar for spraying or spreading can be had for under $1750.
Just enter in the width of strip you want to cover.
Drive your first pass and then it will guide the following passes at your set footage. Acturate to 6 inches or so. If the light goes off center you move the other way.
