TractorLinks.com
Tractor Talk Discussion Forum
Re: Hot thermostat
Aaron Ford
12-30-2013 13:41:16
I put a 160 degree in when I first put my tractor together. It ran okay, but not right. The other problem is that it sooted really bad. My exhaust is vertical and I always had the stuff on my face and clothes.
I run the hottest I can in everything else, so I switched it out for a 195 degree. It runs much cleaner, peppier, smoother, etc. The only downside is that I don't really work it hard enough in hot weather (or any weather) to ever get it to set on 195. It swings from 180 to 195.
I suspect when the thermo opens, the cold water of the radiator causes it to slam back shut. It creeps up to 195, then drops fast to 180 then begins its slow climb again, over and over. It still runs rings around the same tractor with a 160 degree thermostat but the temp swings drive me nuts! The tractor is a 1959 MF65
Aaron
Indiana Ken
12-30-2013 16:54:38
 Re: Hot thermostat in reply to Aaron Ford, 12-30-2013 13:41:16
In years past many thermostats had a small hole to allow coolant to bypass when the thermostat is closed. Some of the new thermostats do not and I think they can seal too tight. Without flow the thermostat cannot get a good reading of the temperature since the flow is dead headed. I like to drill a 1/8" to 3/16" hole to allow a small amount of coolant flow. Might try it, if the thermostat you are using does not have a hole.
Aaron Ford
12-30-2013 17:41:38
 Re: Hot thermostat in reply to Indiana Ken, 12-30-2013 16:54:38
My thermostat lays flat level so I drilled one in it! 3/64ths if I recall correctly. I don't think I work the tractor hard enough and the cooling system was completely gone through. It may be working too good. I have considered putting cardboard in front of the radiator to try to retain some heat. I suspect the direct drive fan isn't helping much either. Even with my wonky temp swings, I like it better this way. Uses less fuel, too.
Aaron
Indiana Ken
12-31-2013 05:44:45
 Re: Hot thermostat in reply to Aaron Ford, 12-30-2013 17:41:38
A 3/64" hole is pretty small. Certainly it will eliminate those pesty air locks when filling the system but the bypass flow is not significant. Consider that flow is a function of cross sectional area. It takes 7, 3/64" holes to equal 1, 1/8" hole or 16, 3/64" holes to equal 1, 3/16" hole on a cross sectional area basis.
Yes, covering the radiator in cold weather is a good idea. I run my 8N with a piece of cardboard that covers most of the radiator. Of course the cardboard comes out as soon as the weather warms and for heavy work.
buickanddeere
12-31-2013 08:50:12
 Re: Hot thermostat in reply to Indiana Ken, 12-31-2013 05:44:45
Careful with the cardboard blocking the rad. If the fan is loaded and unloaded as it rotates. The blades will flex and on occasion break.
Indiana Ken
12-31-2013 16:35:16
 Re: Hot thermostat in reply to buickanddeere, 12-31-2013 08:50:12
Very pro-found observation concerning covering the fan. Typically I block the entire area in front of the fan, plus some, simply to block enough air to get heat into the engine. In the future I will be sure to watch how the fan is covered.
buickanddeere
12-30-2013 16:57:58
Agreed. A wee vent is required in the stat of equipment that does not have a bypass.
