Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Talk Discussion Forum
MF-65 GAS starts hard with gas cap on
Rkh
12-30-2013 10:34:16
MF-65 GAS starts hard cold-take gas cap off & runs. used air compressor to clean gas cap vent-didnt help, but starts when cap off. any ideas why?
Aaron Ford
12-30-2013 13:26:21
 Re: MF-65 GAS starts hard with gas cap on in reply to Rkh, 12-30-2013 10:34:16
I didn't have your problem, but leaving the gas cap on the rear tire and taking off sure cured any problems my old cap had... Sounds like something is plugging it up. I bought mine here.
Aaron
Ted in NE-OH
12-30-2013 12:59:25
Coincidence or the tractor is thinking too much.LOL
old
12-30-2013 12:07:44
Aboutthe only thing that could be wrong is the vent is still clogged up. You may need a new cap if the vent is in the cap or you need to run A wire or other such think to clean the vent out
2badlybent
12-30-2013 13:47:15
 Re: MF-65 GAS starts hard with gas cap on in reply to old, 12-30-2013 12:07:44
I don't think the cap vent has anything to do with starting. If the cap vent was plugged it would be noticed after a few miutes of running as gas leaves the tank it will build up a vacuum tht could cause the tractor to act like it is ruuning out of fuel.
I would suspect that your carburator needs service.
old
12-30-2013 15:51:49
 Re: MF-65 GAS starts hard with gas cap on in reply to 2badlybent, 12-30-2013 13:47:15
If he had said it would start then die I would tend to agree but he says it will not start if the cap is on but will with it off so has to be a vent problem or some odd sort
Waltdavies
12-30-2013 16:37:43
 Re: MF-65 GAS starts hard with gas cap on in reply to old, 12-30-2013 15:51:49
Maybe it's shorting out the ignition are connected in any way?
Walt
