TractorLinks.com
Tractor Talk Discussion Forum
Re: ford 2000 firing order
old
12-30-2013 08:44:40
1,2,4,3 is the correct firing order as per the manual. But you maybe thinking the rotor spins differently so you could be getting the firing order wrong or it may have a valve or two that is set to tight or worse burned
ed vroom
12-30-2013 10:18:45
 Re: ford 2000 firing order in reply to old, 12-30-2013 08:44:40
thanks old: The rotor spins clockwise, and to get firing order per manual I would have to change 3 wires, which have tried and doesn't work. I thought if valves were stuck or burnt it would be found with compression test?
old
12-30-2013 11:43:45
 Re: ford 2000 firing order in reply to ed vroom, 12-30-2013 10:18:45
It may also have bad distributor shaft bushings so the points do not open correctly on all 4 lobes or it could also have a bad distributor cap
