Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Talk Discussion Forum
ford 2000 firing order
ed vroom
12-30-2013 07:36:46
50.187.74.197
Hi: I,m working on my friends ford 2000 serial # 21201. The tractor runs smooth at idle and reveed up, but doesn't make the power it should. Compression is good in all cylinders. The distributors is in right firing on # 1 when timing marks are up. The firing order on dist cap is wrong 1432. When the firing order is installed right 1243, it just backfires and wont run. Can't figure it out. Any help
[Reply]   [No Email]
Blackhole49
12-31-2013 07:34:01
71.227.10.245
 Re: ford 2000 firing order in reply to ed vroom, 12-30-2013 07:36:46
Don't know if this will help, But I worked on a 2000 once where the for=ur sided nut on the distributor shaft that opens the points had turned on the shaft. It was a bear to find. I re-positioned it and prick punched it as a temporary fix.
[Reply]  [No Email]
old bc
12-30-2013 21:28:51
69.29.152.83
Worn distributor shaft bushings.
[Reply]  [No Email]
bobbyboywestcentIN
12-30-2013 12:27:45
50.148.11.193
you say it runs smooth at idle and reved up and has good compression, but doesn't have power it should. doesn't sound like an engine problem at all. is the clutch slipping? or maybe you just expect too much out of the little 2000. perhaps we need more info.
[Reply]  [No Email]
RWK in WI
12-30-2013 12:20:19
75.86.137.75
Since no one mentioned it yet - There is a small clip that goes in the distributor if that is missing it won't run right.
[Reply]  [No Email]
ed vroom
01-03-2014 13:28:49
50.187.74.197
 Re: ford 2000 firing order in reply to RWK in WI, 12-30-2013 12:20:19
thanks rwk any more detail about this small clip?
[Reply]  [No Email]
Al Nickel
12-30-2013 11:11:42
50.67.54.115
I would not think that direction of rotor travel would impact on firing order.
All 4 cylinder motors that I have seen thus far have the 1342 firing order....
Can this old guy be educated??
[Reply]  [No Email]
bobbyboywestcentIN
12-30-2013 12:31:44
50.148.11.193
 Re: ford 2000 firing order in reply to Al Nickel, 12-30-2013 11:11:42
if you hooked your wires to the cap thinking it spun one way but actually it spun the other way, the firing order will be all screwed up.
[Reply]  [No Email]
old
12-30-2013 08:44:40
209.86.226.57
1,2,4,3 is the correct firing order as per the manual. But you maybe thinking the rotor spins differently so you could be getting the firing order wrong or it may have a valve or two that is set to tight or worse burned
[Reply]  [No Email]
ed vroom
12-30-2013 10:18:45
50.187.74.197
 Re: ford 2000 firing order in reply to old, 12-30-2013 08:44:40
thanks old: The rotor spins clockwise, and to get firing order per manual I would have to change 3 wires, which have tried and doesn't work. I thought if valves were stuck or burnt it would be found with compression test?
[Reply]  [No Email]
old
12-30-2013 11:43:45
209.86.226.58
 Re: ford 2000 firing order in reply to ed vroom, 12-30-2013 10:18:45
It may also have bad distributor shaft bushings so the points do not open correctly on all 4 lobes or it could also have a bad distributor cap
[Reply]  [No Email]
andymd
12-30-2013 07:41:14
69.35.210.122
try 1342
[Reply]  [No Email]
ed vroom
12-30-2013 10:21:46
50.187.74.197
 Re: ford 2000 firing order in reply to andymd, 12-30-2013 07:41:14
thanks andymd: If the rotor turned counter clockwise that would be correct firing order, but it spins clockwise. I tried it anyway and it just popped and ran rough. Didn't know if there were any other people with this problem?
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
