For 4020deereboy--Big Kubota question..
OliverGuy
Here's what I do with mine, works great.
Another season!! You might laugh, but I got in a pinch to finish and used it to pull a 9 shank chisel in kind of sandy ground. I wouldn't say that it's made for that but it did the job for that day (only 8 acres)
That is a lot of tractor for the money. That's an M125X. 5 cylinder turbocharged diesel with 356 cu in of displacement. That's not the tractor you referred to in your earlier post where you thought you were looking at a 108S. If that is the case, you were looking at a tractor with a 4 cylinder turbocharged and intercooled diesel engine with 230 cu in of displacement which will make it a weak sister when compared to OliverGuy's tractor above. In fact, OliverGuy had either an M100 or M110 which had that smaller engine and ended up trading it for the M125X.
Now that does look nice. I see you've upgraded your planter. Also appear to be interplanting beans. I go to the field with the same colors. Also end up with rocks in the loader no matter how many times I've planted and worked those fields before.
not running down Kubota tractors,but every time someone asks what I think of then I remember what an old gentlemans reply was to another ,regardless of how good they may be I haven't forgot WWII
Dang, you have a good memory! It was a M105 with no guts, you are right. This 125 is quite a bit more machine.
