TractorLinks.com
Tractor Talk Discussion Forum
Re: Hot Water Heater
old
12-15-2013 12:04:44
Take 1 wire off the lower element. Be sure to first turn the breaker off. Check the ohms. You should get a pretty low reading if it is good. If your reading is real high most likely the lower element is bad. On most water heaters electric that is it takes a 1-1/2 inch socket to remove the element. Also likely if you have hard water to have a good bit of lime build up and if you do you need to take a shop vac and rig up a pipe on it to suck out a lot of the lime or a new element will not last long.
BTDT to many times over the years
