Yesterday's Tractor Co. We Have the Tractor Parts You Need
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Talk Discussion Forum
MF-65 Gas with no Thermostat
Rkh
12-15-2013 08:23:07
74.69.153.220
can a MF-65 Gas engine run good & safely without a thermostat? how can I test radiator cap?
[Reply]   [No Email]
Rkh
12-18-2013 04:27:58
74.69.155.241
 Re: MF-65 Gas with no Thermostat in reply to Rkh, 12-15-2013 08:23:07
replaced thermostat & used Napa self adhesive gasket & leaked without the tractor running. anyone use this & is cork the best gasket to use with permatex?
[Reply]  [No Email]
NoNewParts
12-16-2013 07:48:10
67.240.141.151
like all the posters say, you need one.
Especially on a/any tractor which came from the factory
with a cooling system WAY over-engineered for
such small engines.
They were designed to cool under full load all day at 90 degrees,
so under light duty, they will never warm up without a thermostat
at any outdoor temperature.
[Reply]  [No Email]
Don-Wi
12-15-2013 11:22:26
66.87.77.105
I'd find another mechanic....
Donovan from Wisconsin
[Reply]  [No Email]
buickanddeere
12-15-2013 10:42:50
209.240.119.130
What are you trying to "save" by not running a stat ? Install a 195F and the engine will last longer and burn less fuel.
[Reply]  [No Email]
Rkh
12-15-2013 11:20:03
74.69.153.220
 Re: MF-65 Gas with no Thermostat in reply to buickanddeere, 12-15-2013 10:42:50
my mechanic says dont need to use thermostat when we changed leaking hose last year-ran for 1.5hrs plowing this morning & kept stalling. felt rad cap and it was cold as ice.
[Reply]  [No Email]
Billy Shafer
12-16-2013 08:12:52
173.185.114.45
 Re: MF-65 Gas with no Thermostat in reply to Rkh, 12-15-2013 11:20:03
Maybe he is hoping you will bring the engine to him for repairs. When it craps out.Thermostats are there for a reason.
[Reply]  [No Email]
merlynr
12-16-2013 08:31:20
166.147.104.34
 Re: MF-65 Gas with no Thermostat in reply to Billy Shafer, 12-16-2013 08:12:52
My IH454 has no place for a thermostat and the owners manual doesn't mention it anywhere. It's the gas model.
[Reply]  [No Email]
Stick welding
12-15-2013 12:49:26
96.53.210.246
Your mechanic? I don't think the certificate that comes in the Cracker Jacks box qualifies someone as a mechanic. A thermostat is an important part of an engine that shouldn't be over looked. It lets the engine run at consistent proper temperature.
[Reply]  [No Email]
David G
12-15-2013 09:38:18
205.215.206.18
Good advice here, prudent to follow it.
[Reply]  [No Email]
Jason S.
12-15-2013 08:58:04
174.237.2.182
No thermostat will increase engine wear,increase sludge build up, increase fuel consumption, and foul out spark plugs sooner, as well as the condensation problem that has been pointed out. Always run a thermostat in it.
[Reply]  [No Email]
old
12-15-2013 08:51:46
209.86.226.56
Any engine that is water cooled need a thermostat so that they will run hot enough to burn off condensation. If your does not have a thermostat that means some one removed it probably due to it running hot. This time of year you really do need a thermostat in one so it will run as it should
[Reply]  [No Email]
Blackhole49
12-16-2013 07:03:06
71.227.10.245
 Re: MF-65 Gas with no Thermostat in reply to old, 12-15-2013 08:51:46
Old, where are the thermostats in my F20s?
[Reply]  [No Email]
ih_bug
12-17-2013 21:48:11
67.58.196.191
 Re: MF-65 Gas with no Thermostat in reply to Blackhole49, 12-16-2013 07:03:06
is the f20 not a thermosiphon system? and used the shutters.
[Reply]  [No Email]
old
12-16-2013 08:05:31
209.86.226.32
On an F-20 I believe they used a shutter system to do the job of making them run as warm as they should have. Like on my 1935 JD-B which has the shutters on it
[Reply]  [No Email]
Mike Kork
12-15-2013 08:35:14
184.147.201.136
Good & safely, no it will run cold and you will end up with lots of condensation in the crank case. Unless you are located in tropics or don't run it when temperatures are below 70.
Rad cap you test with a rad cap tester, but for the price of a new cap just replace it if you suspect it is not holding the right pressure.
This post was edited by Mike Kork at 08:43:07 12/15/13.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
