Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Talk Discussion Forum
Re: still using a 806
buickanddeere
12-06-2013 21:59:47
International Harvester 806
1963 - 1967
Standard-tread tractor
Next model: International Harvester 856
Larger: International Harvester 1206
Smaller: International Harvester 806 Manufacturer: International Harvester
Total built: 8,052
Original price (USD): $6,800 (1967) Variants:
IH 806: standard-tread
Farmall 806: row-crop International Harvester 806 Engines: International Harvester 5.9L 6-cyl diesel Interntional Harvester 4.9L 6-cyl gasoline International Harvester 4.9L 6-cyl LP gas
full engine details ... Capacity:
Fuel: 42 gal [159.0 L] 48 gal [181.7 L] (LP)
Hydraulic system: 17 gal [64.3 L] Rear Hitch:
Type: IH Fast Hitch 3-Point Hitch:
Rear Type: II Power Take-off (PTO):
Rear PTO: independent
Rear RPMs: 1000 540/1000 Dimensions & Tires:
Wheelbase: 91 inches [231 cm]
Weight: 8460 to 9220 pounds
Front tire: 7.50-20
Rear tire: 18.4-34
full dimensions and tires ... 806 Serial Numbers:
1963: 501
1964: 1403
1965: 3758
1966: 5917
1967: 7409 International Harvester 806 Power:
Drawbar (claimed): 86.6 hp [64.6 kW]
PTO (claimed): 94.93 hp [70.8 kW] Mechanical:
Chassis: 4x2 2WD 4x4 MFWD 4WD (optional)
Steering: hydrostatic power
Brakes: hydraulic dry disc
Cab: Open operator station Hydraulics:
Type: open center
Capacity: 17 gal [64.3 L]
Pump flow: 12 gpm [45.4 lpm] 3 gpm [11.4 lpm] (PTO pump)
Total flow: 24 gpm [90.8 lpm]
Steering flow: 9 gpm [34.1 lpm] Electrical:
Ground: negative
Charging system: generator
Charging amps: 25 Battery:
Number: 2 (diesel) 1 (gas/LP)
Volts: 6 (diesel) 12 (gas/LP)
Amp-hours: 170 (diesel) 60 (gas/LP)
