Yesterday's Tractor Co. Affordable Parts, Just in Time
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Talk Discussion Forum
95 f250 rear brakes
Don-Wi
12-06-2013 11:29:42
75.207.218.70
Doing front end work on my truck (2wd 5 sp. 5.8L) and I pulled the drums off the rear to inspect. Found one wheel cylinder leaking. Hardware is crusty but the shoes and drums are like new. Also the parking brake cables need to be replaced (small cable inside drum is gone on Drivers side too) and I'm wondering, how in the world do I replace the wheel cylinders? the hardware for the parking brake is in front, and it's been siunce high school that I did anything to drum brakes, but I never did anything than a 1/2 ton. This one has me a little confused...
Donovan from Wisconsin
This post was edited by Don-Wi at 11:31:30 12/06/13.
[Reply]   [No Email]
Don-Wi
12-06-2013 20:07:18
75.207.218.70
 Re: 95 f250 rear brakes in reply to Don-Wi, 12-06-2013 11:29:42
The old ones are metric, new ones are inch. Otherwise look to be exactly identicle. Bought from Rockauto and the part numbers match up. I'll get new flanged head bolts tomorrow from the hardware store.
[Reply]  [No Email]
504
12-06-2013 19:51:13
199.127.54.155
If the bolts won t fit the new Cylinders you have the wrong ones. Take one of your old ones apart and read the size on the back of the cup. DO not let you master cyl go empty while you have the lines off, a little vacuum line and a bolt will stop the leaking. The nut on the parking brake arm is a locking nut do not get it too tight. Almost forgot, use the old washers, do not use new unless the old ones leak. ASE retired.
[Reply]  [No Email]
Don-Wi
12-06-2013 18:18:42
66.87.79.51
I'm just glad I can squeeze it in the garage. not much room behind and just enough room to walk in front, but it's all I need. It all started with the radius arm bushings being shot. figured I'd do the ball joints since I was in that far. then the shocks. then the brake hoses looked bad. then I looked in the drums....
Now, 15 minutes after all the stores are closed, here I sit ready to put the new wheel cylinder in and the old bolts are the wrong thread, and the new ones didn't come with any. the old ones are metric threads I think (8MM) and the new ones are 5/16. talk about frustrating.
Not too mention the new brakes hoses for the front didn't come with the retaining clips, and I didn't order them. Nobody local had then in stock that I have found yet. same with the copper washers for the banjo bolts...
[Reply]  [No Email]
Don-Wi
12-06-2013 12:25:25
66.87.79.51
figured it out. had a nut on the back side holding it all on. I'm just gonna take the whole thing with me when I go get the hardware I need yet. already had everything else off, just had to get the last nut.
I took my phone with a forward facing camera and suck that back there with a light. easily showed me what I was missing. now I'm standing in front of the torpedo heater to warm up some. 0 degree wind chill outside today.
[Reply]  [No Email]
Dick W.
12-06-2013 18:31:05
174.54.58.169
 Re: 95 f250 rear brakes in reply to Don-Wi, 12-06-2013 12:25:25
Make sure to clean everything on that top bolt. That way your parking brake will work and release properly when you are ready to drive.
[Reply]  [No Email]
robgIN
12-06-2013 14:35:39
76.208.4.10
sounds like you got it, yes there is a nut, about 7/16 maybe if I remember right that holds the park brake lever that was in your way of removing the wheel cyl. Sometimes that brake line can be a pain to get loose too.
[Reply]  [No Email]
super trucker
12-06-2013 12:46:54
99.150.161.235
Gland you got it. Why does it seem something always go's south when it's stupid cold?
[Reply]  [No Email]
danmcdonald
12-06-2013 12:25:25
198.229.247.252
Remove the shoes first the brake cable will just hang there holding the shoe and you will see how it is held in its not that bad to remove.
[Reply]  [No Email]
super trucker
12-06-2013 12:19:51
174.150.126.99
You basicly stripping it right down to the backing plate. You have to pull the shoes loose to pop the pins out of the shoe and cyl. Not a fun job but highly recomend replacing everything. While your under there look at the load valve in the middle above diff. They are notorious for freezing up and not letting the rear brakes work. Hold on to your hat if you have to replace it.
[Reply]  [No Email]
El Toro
12-06-2013 12:13:26
96.244.7.206
I replaced the rear brake shoes and cylinders on my 1981 Cougar as they were leaking. I replaced the brake lines too. The small bolts holding the cylinders broke, but you get new bolts with the new cylinders. Hal
PS: I put a little anti-seize on the bolts.
[Reply]  [No Email]
Don-Wi
12-06-2013 12:07:56
75.207.218.70
I get that- but you can't get it out with the self adjusting hardware in front of it. What's holding it in? a clip on the back?
I have the bolts and line off the drivers side, and am a little stuck right now. I have to go get the self adjuster repair kit in town yet, and possibly a few other things I find between now & then
[Reply]  [No Email]
super trucker
12-06-2013 12:03:26
174.150.126.99
If you look on the back side of backing plate you will see 2 small bolt heads on either side of brake line . A little hint warm the brake line fitting up with a propane torch and touch it with bees wax or toilet wax ring. The line will spin loose rather than twisting the line off.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
