Russell Dewsnup
I recently acquired my grandfathers 1945 Farmall M. The tractor is well used but runs. I started it and drove it on the trailer to haul home. My question is concerning whether or not to overhaul the engine. I did a compression test and had 60lbs in the front two cylinders, and 70lbs in the back two cylinders. I can see the front and rear seals are leaking and will need to be replaced. Should I overhaul the engine while I have it out of the tractor? The tractor will be used for parades and tractor shows, it will do some fun pulls at the county fair. Thanks for any and all comments.
