Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Talk Discussion Forum
Re: fluid level in a rear tire
David G
10-25-2013 07:38:03
They will tend to surge if not full. The fluid goes over the top like a waterwheel when you are going down the road.
buickanddeere
10-25-2013 08:41:56
 Re: fluid level in a rear tire in reply to David G, 10-25-2013 07:38:03
How is that a problem? Test results show that tires filled to 3&9 o"clock provide a better ride, use less fuel and provide more traction per lb of ballast . Compared to tires filled to 12 o"clock.
Tx Jim
10-25-2013 09:15:35
 Re: fluid level in a rear tire in reply to buickanddeere, 10-25-2013 08:41:56
buickanddeere said: (quoted from post at 11:41:56 10/25/13) How is that a problem? Test results show that tires filled to 3&9 o"clock provide a better ride, use less fuel and provide more traction per lb of ballast . Compared to tires filled to 12 o"clock.
Would you please furnish a copy of your so-called test results?? Back when I worked for a dealer I was taught to fill tires even with valve stem when valve was at 12 o'clock.
This post was edited by Tx Jim at 09:17:17 10/25/13.
buickanddeere
10-26-2013 07:02:01
 Re: fluid level in a rear tire in reply to Tx Jim, 10-25-2013 09:15:35
Test results on either the Firestone or Titan ballast section of their farm tire site. Don"t like the info, blame the calibrated test equipment
Tx Jim
10-26-2013 09:08:18
 Re: fluid level in a rear tire in reply to buickanddeere, 10-26-2013 07:02:01
So are you stating that I need to "GOOGLE" to find out you're "stretching the truth"??????
buickanddeere
10-26-2013 13:04:58
 Re: fluid level in a rear tire in reply to Tx Jim, 10-26-2013 09:08:18
I'm helping you by encouraging you to get out there and exercise by chasing down the info.
Tx Jim
10-26-2013 14:03:50
 Re: fluid level in a rear tire in reply to buickanddeere, 10-26-2013 13:04:58
I'm encouraging you to provide FACTS to some of absurd statements. Facts talk-BS not so. Sorry if you can't back it up then it must your imagination. :wink:
David G
10-25-2013 10:10:22
Jim,
I figured I better play nice and not question the manual.
David G
10-25-2013 08:46:51
You will feel it surging when going down the road, I would not agree it rides better.
Copyright © 1997-2015 Yesterday's Tractor Co.
