I have a power angle plow from a truck (all single acting cylinders) I am putting it in my tractor(Ford 600) with a front mount pump and control valves for a loader (double acting cylinders) I can get power beyond off my loader valve. The plow control valve (older fisher valve) has small ports than the loader valve. Is there any way I could plumb the plow control valve into the loader hydraulics so I will have lift and power angle? The loader valve has 1/2" pressure line in - the plow valve has 3/8" pressure line in. Will the reduction in pressure line cause an issue? Thanks for your help.
