TractorLinks.com
Tractor Talk Discussion Forum
Re: Those blasted trailer brakes
RayP(MI)
10-19-2013 14:10:25
rr - We've been having fits with lighting on wife's utility-cargo trailer that wife uses to haul wool products to fiberfests. Replaced plugs, wiring, etc. Seemed to work OK with my car, not hers. Crank up camper was the same way. Plug in LED tester would show good at the adapter plug (round 7 to flat 4) every time. On camper, I ran a separate ground from frame of trailer to trailer hitch mount on car. Worked some better. Was sure I had a grounding issue. Which I did... Finally took factory connector off the bracket on the car. Turns out that it is an adapter, to ANOTHER connector plug in the wiring harness. Got it apart, cleaned up the one corroded looking connector in the bunch, put some corrosion resisting grease in it and it seems to be working OK. I would sure do a real serious check of grounding. Even to running a separate frame to frame ground wire - just to ssee what happens. Good luck, neighbor.
