Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Talk Discussion Forum
Re: Massey 2200 industrial tractor
b2200
10-19-2013 09:07:44
I will add that this tractor does have a 3 point hitch. This is not the lever that controls that. Those controls are higher up
Dieseltech
10-19-2013 10:06:43
 Re: Massey 2200 industrial tractor in reply to b2200, 10-19-2013 09:07:44
The lever is rate of drop for three point hitch. If set right internally forward is fast and back is slow.
b2200
10-19-2013 10:17:28
 Re: Massey 2200 industrial tractor in reply to Dieseltech, 10-19-2013 10:06:43
ok that makes sense. Will try it out. Thanks
Bob N.Y.
10-19-2013 09:23:22
Two stage clutch = Live PTO. Push the clutch pedal down half way to stop the ground travel and shift gears. Push it down all the way to engage, disengage or stop the PTO. Sounds like you are trying to operate it as if it had Independent PTO. I have no idea what that lever is for. What is the other end connected to?
b2200
10-19-2013 09:36:33
 Re: Massey 2200 industrial tractor in reply to Bob N.Y., 10-19-2013 09:23:22
Yes, I was thinking it had an independent live pto. Will check into the single/ dual stage clutch part of things. That lever is controlling something that goes right in the transmission/ differential area. I'm not sure if this controlling hydraulic flow or pressure perhaps. Can't be anything for the flow of the front end loader because that pump runs off the front or the crankshaft and that whole hydraulic system seems external to the tractor itself. I haven't played with it yet. Was wanting to know what it does before I fooled around with it. Was thinking it must have something to do with either the PTO or the 3 point hitch?
Copyright © 1997-2015 Yesterday's Tractor Co.
