OT: where to sell a walnut stump
2x4
actually the stump is still on the tree. River undercut it & whole tree toppled beside the river but not in it. Have it limbed & topped & will pull it up into the bottom tomarrow with the New Holland. Logs won't be worth much but the root is about 6 ft. long & 30 inches in diameter. Walnut stumps are highly valued for making gunstocks but I need to find a buyer. Your experience or knowledge?
2X4,
I don't know about stumps, but I sold some black walnut logs to a local saw mill a few years ago.
They fetched a good price. Sawyer said that they would be used to produce walnut veneer for furniture makers.
Tom in TN
We gave a large walnut stump to a freind of ours that was a wood sculpter. He carved animals,gun grips & stocks and made spinning wheels (they actually would spin wool). The only way he would take is that we had to dig it out. After it was out he came in with a two man chainsaw and blocked it the the way he wanted it. You might run an add in some gun magazines or look for someone that makes custom stocks.
unless they have started taking 6 ft. veneer, these are only sawlogs. One big knot right where it shouldn"t be spoils that. Local mills only pay lowest prices & claim they don"t deal in walnut if they can help it. It"s them or nobody & they know it. And its only one tree.
the logs are small & low grade. It's the root I need to peddle to high-end buyers.
I had heard the above-ground 16 inches or so needed to go with the root part, as one piece but didn't hear an overall length figure.
(quoted from post at 10:38:27 10/19/13) the logs are small & low grade. It's the root I need to peddle to high-end buyers.
Other than veneer, you will always come out ahead if you get it milled and then sell. I don't sell logs, only boards. Then the customer can see exactly what they're paying for, no surprises.
Bandsaw mills are usually available for hire, or even a chainsaw mill will work fine. I've sold a lot of boards from both. Low grade is a big deal to a mill, but some customers prefer the defects, "character". When you sell direct, it's whatever you and the customer agree on. Industry standard has little to do with it.
I had no trouble selling this walnut, milled with a chainsaw. I always mill for figure, not grade.
thanks but I was looking for a fast buck. The dozer injection pump went out and, worst case scenerio, $1600 for a new one. Don't expect this tree to near pay for it but trying to round up bucks for the pump.
Fast? The boards I wanted to sell from that otherwise worthless log went in one day with a craigslist ad. The remainder are stickered here. I then deleted the ad. The buyer got full instruction on how to sticker and dry the boards. I was happy to get half of what you need for your pump.
You might have had the cash in your pocket already. Looking for a peculiar buyer takes far more time than letting one find you. Photos of the product help immensely. That photo worked perfectly.
Good luck.
