TractorLinks.com
Tractor Talk Discussion Forum
Re: submersible pump wire.
Russ from MN
10-16-2013 08:04:04
I have always seen solid wire used on submersible pumps, but I did have one break once. It was probably from improper installation, the pump was down 135 feet and it broke right above the pump. It was also hanging on 160 lb plastic water line (designed for pumps) so the pump probably moved a bit when starting. I shortened everything a couple of feet and taped it together real well and it ran fine.
Brad Buchanan
10-17-2013 07:17:56
 Re: submersible pump wire. in reply to Russ from MN, 10-16-2013 08:04:04
Hey Russ.
It seems that both solid and stranded wire is used. Looks like the installation is the key.
Brad
Mike (WA)
10-16-2013 08:56:27
Pump outfits sell a wire specifically for submersible pumps- can't recall whether its solid or stranded (I'm thinking solid), but was color coded and had very thick, pliable insulation. Single strands, zip tied together, IIRC.
buickanddeere
10-16-2013 08:36:53
Just because it runs doesn"t make it right. If that pump was meggered or operated from a GFI. Odds are it would fail the test or trip the GFI.
Russ from MN
10-16-2013 13:49:20
 Re: submersible pump wire. in reply to buickanddeere, 10-16-2013 08:36:53
It was put back together properly, just shorter! I have never seen a 220V water pump connected to a GFCI.
buickanddeere
10-16-2013 13:55:06
 Re: submersible pump wire. in reply to Russ from MN, 10-16-2013 13:49:20
How did you join the wires? Is the only wire insulation black electrical tape?
Russ from MN
10-16-2013 17:48:59
 Re: submersible pump wire. in reply to buickanddeere, 10-16-2013 13:55:06
They make special approved underwater connection covers, go right over a but connector.
