TractorLinks.com
Tractor Talk Discussion Forum
Re: 260 loader controller
jason west
10-15-2013 10:02:26
okay I just tore the valve out and the inside one is marked in and outside one is out. So the small hose is on the out, soooo... should I swith the larger hose over to the out for return and smaller hose over to in for supply. And just for redundancy, the supply will connect to the top port of PBY block that channels to the small hole inside the top of PBY housing and return will dump into side of PBY that dumps into the main part of Block? Last question I Promise! You guys have been so helpful. Jason West
Tx Jim
10-15-2013 10:39:42
 Re: 260 loader controller in reply to jason west, 10-15-2013 10:02:26
Actually as long as the return hose size is 3/8 in inside diameter it will be FINE. On most JD FEL valves I've seen/worked on the pressure/return hoses were the same size.
