TractorLinks.com
Tractor Talk Discussion Forum
Re: farmall or allis
VicS
10-07-2013 19:32:46
A WD45 diesel while hard to find, but not impossible, is a better puller. The diesel has enough torque to handle 38 inch tires. A D17 diesel would be even better, the diesel is 35 cu in bigger, and it has a high low shift to boot.
Leroy
10-08-2013 06:45:42
 Re: farmall or allis in reply to VicS, 10-07-2013 19:32:46
You put a 38" tire on that AC and you could not pull in a stock class as he said he would like. And a Farmal H or Late John Deere B are just about equal in pulls, M or late A (single stick gas) are just about equal, AC's never do any good, WC competes best with the H OR B but never wins. Cockshutt's are also good but not near as plentifull and harder to find parts or somebody that knows them to work on them. I have been working a stock pull for several years and on the back side of the track you see a lot that you do not see in the spectater area. Only one AC has been in pull consistantly for last 10 years, that being a 39 WC, rest if they are in for 2 years that is about it.
VicS
10-08-2013 18:18:09
 Re: farmall or allis in reply to Leroy, 10-08-2013 06:45:42
I live in Southern Il. And pull in Ind ky and Mo. 99.9 % of Allis's pull with 38 in tires in the stock classes. So you would like to let everybody else use 38 in tires and not let Ford and Allis use them. And yes 38 in tires were a orderable option on a WC WD.
Leroy
10-08-2013 18:44:01
 Re: farmall or allis in reply to VicS, 10-08-2013 18:18:09
You would need the orignal pats book that shows them to do that. Tires are limited to ONE sise over factory on all tractors, no widened out rims.
blue924.9
10-08-2013 06:54:50
yes a wc, the lowest factory powered tractor in its weight class, try a wd or wd45 they have more power stock and can pull the same weight classes, ACs are plenty competitive
Leroy
10-08-2013 13:46:21
 Re: farmall or allis in reply to blue924.9, 10-08-2013 06:54:50
I know what they do not do and that is come back the next year or in two years.. Others are there every year for the past 10-15 years.
Leroy
10-08-2013 13:50:33
 Re: farmall or allis in reply to Leroy, 10-08-2013 13:46:21
And the WC does not run out of power but traction and the same would be for the WD or the WD 45. 2 sets of rear wheel weights and that is it.
blue924.9
10-08-2013 06:54:27
