TractorLinks.com
Tractor Talk Discussion Forum
Re: Inspecting disc mower cutterbar
Waltdavies
10-07-2013 18:55:49
I have an older 12 ft swather the whole cutter bar is worn out the cost is just to much to even try to fix it. The teeth are cheap but the rock guards cost like well you say it. If they are all the same and in fair condition and the cutting edges are clean and sharp then go for it. But make sure it works befor buying.
Walt
KEH
10-08-2013 05:05:22
 Re: Inspecting disc mower cutterbar in reply to Waltdavies, 10-07-2013 18:55:49
Do the checks that the other posers said. Have it hooked to a tractor and hear it run. If you cant run it, don't buy it. Shine a bright light inside the gear box at the oil filler hole , check oil level, rotate the gears and see if any teeth are chipped. If the cutter bar is over filled with oil, that is a sign the bottom seal is leaking oil from the gear box into the cutter bar, especially if the gearbox is low on oil.
KEH
