main engine bearingsvon s 1953 ford jubilee
ejensen
Is it possible to remove@replace the main bearings and replace them without removing the engine?
Yes but if your replacing them due to one knocking it will do little if any good. Once one starts to knock then the crank shaft needs to be pulled out and checked and most likely turned
Old,
Thank you for the information. Motor sounds good I was just curious. Had to remove the engine on my 1948 IHC to remove the rear main
