Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Talk Discussion Forum
Re: Ot, wood splitter problem.
Russ from MN
10-05-2013 16:37:21
Did you run it after you added the oil? It may take some time to work the air out of it. Did you use hydraulic oil? If the oil is foamed it may have to set awhile for the foam to dissipate. If it still does not work properly after all this then the pump is probably bad.
JayinNY
10-05-2013 16:44:58
 Re: Ot, wood splitter problem. in reply to Russ from MN, 10-05-2013 16:37:21
Yes I ran it for a few minutes, but the pump is nosiey, I can run it tomarrow some more, he said it always ran that way? But I don't think it's right. Thanks for the help.
uncletom
10-05-2013 19:25:55
 Re: Ot, wood splitter problem. in reply to JayinNY, 10-05-2013 16:44:58
Friend of mine has one just like it. Was you using it in the vertical position? On his when it was in the upright position it kinked the return hose to the tank and would run slow.
