what model and year?,, can't find serial
jim in az
New User
hi, i don't know what model is can't find any serial # and no decals,, it;s a 4 cyclinder diesel and has a 4 speed tranny and a hi-lo shift .it may be a 30 series but not sure.. it's not in good shape..any help would be appreciated.. thanks jim
it's a case and i posted a pic but it must not come thru wide front. 3 point not rounded front,, square by radiator
i posted pic on tractor photos, but my comment didn't show up 4 cyclinder diesel 4 speed tranny with hi-lo
Looks like a 630 to me. Your serial number is on a missing shield that covers the right side on the fuel tank. The hi-lo shifter is likely a triple range. High Medium and Low. For Low, pull the lever straight out to the right, then push forward.
Your pic should be here.
Paul
agree with Straw Boss a 630 but not a triple range as I can see the Case-O-Matic lever to the right of the steering wheel they were made 1960-1963 look on the lower block on the LH/injection pump side some have a casting date there the motors were one year older than the tractor generally they are rated as a 50hp tractor
thanks to you and paul, ray straw boss,wijim for the info it's not a 3 speed, just 2. problems with it are clutch doesn't grab until all the way out, the convertor was real low on oil, i have right pressure according to gauge,, and i have to ether it to start.. thanks again guys jim
