New Holland 411 problems
JWCarp
Has anyone ever had issues wit the gearbox on a 411? Last night while mowing the blades stopped and there was a RRRRRRRRRRR sound. The rolls are still driving but the blades are not. Since there was not really any gear noise before I can assume that a bearing gave out or a gear slid out of position. I can not believe that all the teeth would suddenly get torn off without a lot more crunching. What issues have you guys had and how easy/expensive was it to fix.
If you didn"t have the tongue locked in the full swung out position, get yourself a new discbine, that one"s not worth as much as the gearbox rebuild will be.
Thanks for the input fellas. The tongue was locked out in the mow position. I will take a peed inside if I can. My local dealer has a few 411's setting the the scrap heap. They may have good gearboxes or they might be there for the exact same reason.
